拆解
We are going to teach you how to take apart and put back together a Cannon Powershot N.
这个拆解是不是维修指南。 要维修你的的Canon PowerShot N,请使用我们的维修手册。
Locate battery housing cover.
Place finger on the textured portion of battery housing cover and slide cover in the direction indicated.
Find beige tab and push it away from the battery.
Remove battery from battery slot with fingers.
Using a PH000 size screwdriver, unscrew four screws beneath screen.
Remove 2 screws on the bottom of the camera.
Remove 2 screws from the side of the camera with the on and off buttons.
Remove the back plate.
Locate 2 screws on “on/off” side of the camera and unscrew them.
Locate 2 screws on the other side of the camera and remove them.
Remove one screw from the bottom of the camera.
Remove front plate from motherboard so that one ribbon cable is exposed.
Locate the second ribbon cable.
Using plastic spudger, push tab to release the ribbon cable.
Locate screw under released ribbon cable and remove it.
With the camera lens facing you, remove 4 screws around the lens.
Flip over and remove 1 screw from side with playback/phone options .
Unscrew 2 screws from top, bottom, and both sides of screen.
Pull off white cap which edges the screen.
Remove white metal plate behind screen (tip: try not to bend).
Push out LCD screen.
与4其他贡献者
于03/04/16注册
313 声望
撰写一个指南
徽章: 2
UMASSD-BHUSAL-S16S6G5
3 名成员
创作了1篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,362
