跳转到主内容
修复你的物品
维修的权力
商店
本拆机指南正在进行中 – 定期刷新以看到更新!
在此拆机指南中使用的工具
简介
The MR-14EX is a 2-piece flash apparatus, designed for close-range macro photography (~1:1 or greater); extreme close-ups, and tiny subjects.
The main controller (DSLR hotshoe mount), and the flash lamps (lens mount), are tethered by a coiled retractile cable.
I decided to make a few personal modifications to my own, so I contacted Canon directly, requesting some information and a service manual. Basically, they refused to co-operate, forcing me to do things the hard way. So now I'm documenting my process; sharing the relevant information with you, as I progress.
Diagrams are adapted from the official spare parts catalogue.
  1. Remove four screws from the top of the main control module. One in each corner. Plus one in the middle. And four more (one is obstructed from view in the photo) at the foot of the module.
    • Remove four screws from the top of the main control module. One in each corner.
    • Plus one in the middle.
    • And four more (one is obstructed from view in the photo) at the foot of the module.
    • The base will drop out quite easily.
    • Be careful. Only one of these cables is designed to be disconnected from this end. If possible, try to pry it with a tool, rather than tugging it.
  2. The outer shell is held together by internal plastic clips. The two halves come apart at the sides. If you can free a single clip, the rest will slip out, and the rest will fall apart with minimum effort. As you can see, I was a bit rough and broke one of the clips a little bit. I'm not too concerned about it, but try to avoid doing the same if you can help it. Some other pieces may fall out. Including the battery hatch, and some metal pieces. I'm not exactly sure what their purpose is. Perhaps structural reinforcement, or something like that.
    • The outer shell is held together by internal plastic clips. The two halves come apart at the sides. If you can free a single clip, the rest will slip out, and the rest will fall apart with minimum effort.
    • As you can see, I was a bit rough and broke one of the clips a little bit. I'm not too concerned about it, but try to avoid doing the same if you can help it.
    • Some other pieces may fall out. Including the battery hatch, and some metal pieces. I'm not exactly sure what their purpose is. Perhaps structural reinforcement, or something like that.
  3. Unplug the various connectors holding it all together.
    • Unplug the various connectors holding it all together.
    • As you can see, I marked up all the plugs and sockets with colour coded paint pens. I recommend doing the same.
    • Only one end of each wiring loom can be disconnected. Inspect with a lamp or refer to my images to make sure you're pulling the right ends.
    • Don't tug on the wiring looms. Some will be stuck tight. I used a long nose plier & hooked pick/probe/scraper.
tjt263
于2014年12月30日注册
112 信誉积分
撰写一个指南
添加评论
浏览统计数据:
过去的24小时: 3
过去的7天: 5
过去的30天: 17
总计 517
