跳转到主内容
CR-10 V2 Print Head Teardown
你所需要的
  1. CR-10 V2  Print Head Teardown, Teardown: 步骤 1 中的图像 1,3 CR-10 V2  Print Head Teardown, Teardown: 步骤 1 中的图像 2,3 CR-10 V2  Print Head Teardown, Teardown: 步骤 1 中的图像 3,3
    • Make sure all power cables to your 3D Printer are unplugged including wall plugs (A/C) and/or USB cables.
    • Using M2 hex remove the 3 button head screws holding the print head to the X carriage plate.
    • Using M2 hex, remove the 4 screws holding the hot end fan in place (2 screws attach to the front half and the other to the rear)
    • Using M2 hex, remove 3 button head screws that secure front and rear sections together. Do not try to pull apart yet!
  2. CR-10 V2  Print Head Teardown, Teardown: 步骤 2 中的图像 1,3 CR-10 V2  Print Head Teardown, Teardown: 步骤 2 中的图像 2,3 CR-10 V2  Print Head Teardown, Teardown: 步骤 2 中的图像 3,3
    • Using M2 hex, remove the 2 button head screws securing the part cooler fan. 1 attaches to the front and the other to 2 rear.
    • Pull the front half off to expose the rear section and hot end.
    • Now, treat it like an E3D V6 hot end. However, the nozzle is not V6 style.
    • The stock nozzle is MK8 just like standard CR-10/ CR-10S
结论
3等其他人完成本指南。
Tiny Machines 3D
于11/16/19注册
2,970 声望
创作了14篇指南
团队
Tiny Machines 3D Tiny Machines 3D 的会员
Community
5 名成员
创作了40篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 23
总计 8,061
