跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
危险
有潜在危险
如果不正确地执行这个步骤,就可能导致受伤。请保持谨慎并注意所有警告。
危险
  1. The Assembled Product, unplugged from wall
    • The Assembled Product, unplugged from wall
  2. Turn Smart Strip upside down and locate  four screw holes in corners Unscrew four corner screws with #0 Phillips Screwdriver
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. Locate four latch slots in case Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  5. Take two halves of case apart with your hands Take two halves of case apart with your hands
    • Take two halves of case apart with your hands
  6. Lift Ground Copper Strip upward off of power plugs by hand
    • Lift Ground Copper Strip upward off of power plugs by hand
  7. Locate latch securing power plugs to bottom of case Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  8. Lift power plugs out of bottom of case along with circuit assembly Lift power plugs out of bottom of case along with circuit assembly
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
于2013年11月14日注册
194 信誉积分
撰写一个指南
This is great! Thanks so much!
nils smith - 回复
that awesome and i like how it fix
Joseph donkor - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 8
总计 1,120
