跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Bluesmart Black Edition,应参考我们的维修指南
  1. Bluesmart Black Edition Teardown, Open Suitcase: 步骤 1 中的图像 1,3 Bluesmart Black Edition Teardown, Open Suitcase: 步骤 1 中的图像 2,3 Bluesmart Black Edition Teardown, Open Suitcase: 步骤 1 中的图像 3,3
    • Open the suitcase.
  2. Bluesmart Black Edition Teardown, Turn off suitcase: 步骤 2 中的图像 1,3 Bluesmart Black Edition Teardown, Turn off suitcase: 步骤 2 中的图像 2,3 Bluesmart Black Edition Teardown, Turn off suitcase: 步骤 2 中的图像 3,3
    • Open this switch cover and power off the device.
  3. Bluesmart Black Edition Teardown, Unzip inner lining: 步骤 3 中的图像 1,2 Bluesmart Black Edition Teardown, Unzip inner lining: 步骤 3 中的图像 2,2
    • Slide the zipper this direction
  4. Bluesmart Black Edition Teardown, Lift away inner lining: 步骤 4 中的图像 1,1
    • Lift it out of the way.
  5. Bluesmart Black Edition Teardown: 步骤 5 中的图像 1,1
    • Unscrew the 4 large Phillips screws
    • Unscrew the 8 smaller Phillips screws
  6. Bluesmart Black Edition Teardown: 步骤 6 中的图像 1,1
    • Remove these 2 large Phillips screws
    • These screws are different than the ones from the previous step. Keep them separate.
  7. Bluesmart Black Edition Teardown, Check: 步骤 7 中的图像 1,1
    • Make sure they are all screws are completely removed before proceeding
  8. Bluesmart Black Edition Teardown: 步骤 8 中的图像 1,2 Bluesmart Black Edition Teardown: 步骤 8 中的图像 2,2
    • Stand the suitcase up
    • Pull up on the handle
    • Only pull as far as shown in the photo, or you will end up breaking cables.
  9. Bluesmart Black Edition Teardown: 步骤 9 中的图像 1,2 Bluesmart Black Edition Teardown: 步骤 9 中的图像 2,2
    • Carefully disconnect the 3 cables connecting the circuit board to the suitcase.
    • Pull by the connector, not by the wires.
  10. Bluesmart Black Edition Teardown: 步骤 10 中的图像 1,1
    • We can now see the bottom of the circuit board. It has a QR code with a serial number or MAC address.
    • It also has a SIM card slot.
  11. Bluesmart Black Edition Teardown, SIM Removal: 步骤 11 中的图像 1,3 Bluesmart Black Edition Teardown, SIM Removal: 步骤 11 中的图像 2,3 Bluesmart Black Edition Teardown, SIM Removal: 步骤 11 中的图像 3,3
    • To remove the SIM card, use your nail to slide the metal bracket back
    • Then, flip the bracket, and slide out the SIM card.
    • Make sure the SIM card is all the way back in the bracket before closing.
  12. Bluesmart Black Edition Teardown, Battery Compartment: 步骤 12 中的图像 1,3 Bluesmart Black Edition Teardown, Battery Compartment: 步骤 12 中的图像 2,3 Bluesmart Black Edition Teardown, Battery Compartment: 步骤 12 中的图像 3,3
    • To replace the battery, remove these 4 Phillips screws.
  13. Bluesmart Black Edition Teardown, Switch Removal: 步骤 13 中的图像 1,1
    • To remove the power switch, remove these 2 small Phillips screws.
    • You will need a smaller screwdriver
  14. Bluesmart Black Edition Teardown: 步骤 14 中的图像 1,3 Bluesmart Black Edition Teardown: 步骤 14 中的图像 2,3 Bluesmart Black Edition Teardown: 步骤 14 中的图像 3,3
    • After removing the screws holding circuit board in place, you flip it down.
    • Cellular/GPS Antennas
    • Empty USB header used in the Bluesmart One
    • Bluetooth module (CC2541)
    • Microcontroller - ABOV 96F4548L (48KB ROM, 2KB EEPROM, 256B iRAM, 1.5KB xRAM)
    • Cellular/GPS Module (ZTE MF206A)
9021007
于07/13/18注册
4,599 声望
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 65
过去 30 天: 266
总计 1,996
