跳转到主内容
修复你的物品
维修的权力
商店
简介
The allure of Spring is in the air. Feel the weather warming up. The hills covered with blooming flowers. And with Spring comes the reemergence of berries, specifically BlackBerrys. The BlackBerry Z10 is BlackBerry's (the company formerly known as RIM) newest flagship smartphone. Join us as we discover the juicy secrets that dwell inside the BlackBerry Z10.
Follow iFixit on Twitter or "Like" us on Facebook for the latest updates on teardowns!
这个拆解是不是维修指南。 要维修你的的BlackBerry Z10,请使用我们的维修手册
  1. The BlackBerry Z10 is finally here. As BlackBerry's first dual-core smartphone, how does it stack up spec-wise? Let's find out. Tech Specs:
    • The BlackBerry Z10 is finally here. As BlackBerry's first dual-core smartphone, how does it stack up spec-wise? Let's find out.
    • Tech Specs:
    • 4.2" display with a resolution of 1280x768 pixels, (~356 ppi pixel density)
    • Dual band (2.4 GHz / 5 GHz) Wi-Fi 802.11 a/b/g/n and Bluetooth 4.0 Low Energy (LE)
    • 8 MP rear-facing camera with autofocus, a 5-element f/2.2 lens (1080p HD Video) + LED flash, and a 2 MP front-facing camera (720p HD Video)
    • 1800 mAh removable battery with up to 10 hours of talk time
    • 2 GB RAM with 16 GB internal flash memory and support for microSD memory cards (expandable up to 32 GB)
  2. It's a relief to see a smartphone in this day and age with a removable battery. You even have the option of charging your phone and a spare battery at the same time.
    • It's a relief to see a smartphone in this day and age with a removable battery.
    • You even have the option of charging your phone and a spare battery at the same time.
    • On the other hand, BlackBerry does warn us not to disassemble our phone because we might find small parts to choke on. Right.
    • Apparently, there is a risk associated with naming your device after food. Worry not, we've found a handy graphic to help you identify the edible ones.
  3. Along the left edge of the BlackBerry Z10, we find two ports: Micro USB 2.0 port (for charging and data synchronization)
    • Along the left edge of the BlackBerry Z10, we find two ports:
    • Micro USB 2.0 port (for charging and data synchronization)
    • Micro HDMI port (output to any HDMI-capable display)
    • The top edge of the Z10 is home to the power button and the headphone jack.
    • We just have to say how great it is to have the headphone jack located along the top of the phone. Props to the BlackBerry hardware design team.
    • Aaaaaaannnd that's it for ports.
  4. Removing the rear case simply requires prying a few clips around the perimeter of the Z10. Easy peasy. The rear panel contains an integrated NFC antenna, similar to the antenna found in the Samsung Nexus S. To avoid running a cable between the body and rear panel, the NFC antenna has two contact points that line up with spring contacts on the motherboard.
    • Removing the rear case simply requires prying a few clips around the perimeter of the Z10. Easy peasy.
    • The rear panel contains an integrated NFC antenna, similar to the antenna found in the Samsung Nexus S.
    • To avoid running a cable between the body and rear panel, the NFC antenna has two contact points that line up with spring contacts on the motherboard.
  5. We couldn't just NOT remove the battery. It felt strange. So yes, we added the battery and then removed it. It was glorious. The 3.8 V, 1800 mAh Lithium-ion battery allows for up to 10 hours of talk time on 3G with up to 13 days of standby time. If you're wondering how the BlackBerry Z10 stacks up to its competitors, wonder no more:
    • We couldn't just NOT remove the battery. It felt strange. So yes, we added the battery and then removed it. It was glorious.
    • The 3.8 V, 1800 mAh Lithium-ion battery allows for up to 10 hours of talk time on 3G with up to 13 days of standby time.
    • If you're wondering how the BlackBerry Z10 stacks up to its competitors, wonder no more:
    • Nexus 4: 3.8 V, 2100 mAh battery with over 10 hours of talk time.
    • iPhone 5: 3.8 V, 1440 mAh with up to 8 hours of talk time on 3G.
  6. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  7. Several screws secure the plastic midframe to the outer plastic frame. Ha! Nice try BlackBerry…Fool us once, shame on you; fool us twice, and we'll be forced to use our spudger to remove a small sticker revealing a hidden screw. With the screws out of the way, the plastic midframe just pops off.
    • Several screws secure the plastic midframe to the outer plastic frame.
    • Ha! Nice try BlackBerry…Fool us once, shame on you; fool us twice, and we'll be forced to use our spudger to remove a small sticker revealing a hidden screw.
    • With the screws out of the way, the plastic midframe just pops off.
    There is a small bit of adhesive on the top ofthe battery connector, that didn't let the plastic midframe just "pop off"...in fact, it was holding it so strongly that I can see someone accidentally breaking it if they are not careful...just used a plastic pry tool to separate it there...
    ddargie - 回复
    Thanks for the heads up, you'd almost think there was an invisible screw there. That adhesive is strong. I just finished so work your way through it. THANKS AGAIN!!!!!!!!!!!!
    Michael Payton -
    Thanks for the heads up. I also thought there was a bit of resistance there, but I thought it was due to the cable connector which I initially forgot to disconnect.
    Nader Zaidan -
  8. This is a surprise. It seems the screws that secured the plastic midframe to the outer case also doubled as fasteners for the motherboard. With the screws already removed, the motherboard is held in place by only a few connectors. Absolutely zero adhesive holding down this motherboard. We'll say that again. Absolutely NO ADHESIVE. Wonderful. It's as free as a bird, now.
    • This is a surprise. It seems the screws that secured the plastic midframe to the outer case also doubled as fasteners for the motherboard.
    • With the screws already removed, the motherboard is held in place by only a few connectors.
    • Absolutely zero adhesive holding down this motherboard. We'll say that again. Absolutely NO ADHESIVE. Wonderful. It's as free as a bird, now.
  9. The rear-facing camera is dispatched from the motherboard with ease. The 8 megapixel auto-focus camera has a 5-element f/2.2 lens, with a dedicated ISP (image signal processor) and 64 MB frame buffer. A Backside Illumination sensor increases the amount of light captured, greatly improving low-light performance.
    • The rear-facing camera is dispatched from the motherboard with ease.
    • The 8 megapixel auto-focus camera has a 5-element f/2.2 lens, with a dedicated ISP (image signal processor) and 64 MB frame buffer.
    • A Backside Illumination sensor increases the amount of light captured, greatly improving low-light performance.
    • The backside of the rear camera is labeled PCB-49527-005.
    Please tell me if it is possible to replace BlackBerry camera with the Sony Xperia Z camera? I want to know if both of these cameras are compatible with each other? Thanks
    hammi_saif - 回复
  10. A few of the major ICs on the backside of the motherboard:
    • A few of the major ICs on the backside of the motherboard:
    • Samsung KLMAG2GE4A 16 GB MLC NAND Flash + Controller
    • Avago ACPM-7051 Quad-Band GSM/EDGE and Dual-Band UMTS (B1/B5) Power Amplifier
    • Inside Secure SecuRead 972-DC-C6 NFC Solution Module
    • Qualcomm WCD9310 Audio Codec
    • ST Microelectronics LIS3DH 3-axis MEMS Accelerometer
    • STMicroelectronics LSM330DLC 3D Accelerometer & 3D Gyroscope
    Just a minor typo -- reads:
    Avago ACPM-7051 Quand-Band GSM/EDGE...
    Shouldn't that be "Quad-Band"?
    petercapriccio - 回复
    Does anyone knows how to remove the caps for the motherboard?
    450mijaou - 回复
  11. Front side of the motherboard:
    • Front side of the motherboard:
    • Samsung K3PE0E000A XG 2 GB Mobile DDR2 SDRAM + Qualcomm MSM8960 Snapdragon S4 Baseband/Applications Processor
    • Qualcomm PM8921 Power Management IC
    • Qualcomm RTR8600 Multi-band/mode RF transceiver, the same one found in the Samsung Galaxy S III and iPhone 5
    • Texas Instruments WL1273L Wireless Module (802.11a/b/g/n, WLAN, Bluetooth, and FM)
    • TriQuint TQP6M9017 Dual-Band WLAN Module
    • RF Micro Devices RF7252 Linear Power Amplifier Module
    • Avago ACPM-5017 LTE Band XVII Power Amplifier
    • With the motherboard out of the way, we're ready to tackle the display assembly.
    • It's held in place with several smaller-than-usual screws (T2 Torx) and just a few light adhesive strips—no match for our prying experts.
    • Peeling the display assembly off the outer plastic frame reveals a convenient pocket-mirror on the back of the LCD. Convenient for anyone who cares more about reflections than a functional Z10.
  12. The display unit is ultra thin, a feat achieved by some serious fusing. The digitizer is applied directly to the glass and fused in turn to the LCD. The downside: Shattering the glass  means losing all touchscreen capabilities. A drop from ear-height on concrete spells death. The glass is not the lauded Gorilla Glass, but a new kind of hardened display.
    • The display unit is ultra thin, a feat achieved by some serious fusing. The digitizer is applied directly to the glass and fused in turn to the LCD.
    • The downside: Shattering the glass means losing all touchscreen capabilities. A drop from ear-height on concrete spells death.
    • The glass is not the lauded Gorilla Glass, but a new kind of hardened display.
    • The display gets three cables which correspond to, as far as we can judge, the LCD, digitizer, and backlight.
    • The digitizer cable is home to the Synaptics Clearpad 3203 Capacitive Touchscreen Controller to manage all the snazzy Z10 gestures.
  13. While major components come out of the BlackBerry Z10 without much fuss, once you get down to the small case peripherals, things get a little more dicey. The headphone jack, power switch, ambient light sensor, and earpiece speaker housing are built into a single assembly, held in place with some tough adhesive. We set our spudger to work against more adhesive, this time holding the rotary vibrator motor very securely in place.
    • While major components come out of the BlackBerry Z10 without much fuss, once you get down to the small case peripherals, things get a little more dicey.
    • The headphone jack, power switch, ambient light sensor, and earpiece speaker housing are built into a single assembly, held in place with some tough adhesive.
    • We set our spudger to work against more adhesive, this time holding the rotary vibrator motor very securely in place.
  14. BlackBerry Z10 Repairability Score: 8 out of 10 (10 is easiest to repair) The battery can be replaced without any tools.
    • BlackBerry Z10 Repairability Score: 8 out of 10 (10 is easiest to repair)
    • The battery can be replaced without any tools.
    • Motherboard and display come out with little difficulty and are held in place with little adhesive.
    • Standard screws are used throughout the device.
    • Although the display assembly comes out fairly easily, the LCD is fused to the glass, increasing cost of repair.
    • Smaller components (headphone jack, camera) are modular and can be replaced individually, but have somewhat strong adhesive holding them in place.
Does anyone know where to buy replacement parts for this phone?
marcaucoin - 回复
I found that you can buy almost anything cheaply from China. etradesupply.com, which I got to via e-bay links, seems to have lots of Blackberry parts, and if you can't find a picture of the part you want, they can often find it if you ask. For example, I got a new micro SD card reader for my Classic, though all the pics were of SIM readers till I asked. After that I had several all trying to outdo each other on tiny prices that wouldn't even cover the postage in this country! Many of them come with the necessary tools for the strip down free too.
Incidentally, some of the suppliers listed are flogging off broken phones for spares or repair very cheaply too, so, if it's buttons and the like you want, just buy a broken phone.
Spamlet -
I have found that this requires a T1 and T3 Torx. Not a T2 and T4 as advised above.
Dan Bullock - 回复
Can you provide details on what cellular service provider you obtained this phone from, or is it unlocked? Is it from the US or an overseas version?
Clifford - 回复
I have what looks like a small circle of rubber, maybe thermal paste, between my Snapdragon and the case that isn't pictured in the teardown.
And I think the T1/T3 comment is spot on. I used a T3 to remove all the main screws, but don't have anything small enough to take out the monitor, at the moment.
Tom Burke - 回复
agreed @ T1 and T3.
Although I've abused the T2 (I've order here because of this article...) for both T1 and T3...
thomassenyk -
Thank you! This guide was very helpful when replacing my screen & digitizer.
Mine also had the 'thermal paste' that Tom described. I was able to get away with a T4 or T3 on the 'larger' screws and a T2 for the small ones.
This video was also helpful as a walkthrough:
http://n4bb.com/replace-blackberry-z10-l...
Regards
Colin Wyndham - 回复
I also used a T3 to repair touchscreen and lcd. Also added some thermal paste.
Thanks very much for this nice how-to tutorial. Greetz from Belgium.
Pierre - 回复
My cellphone is Blackberry Z-10 STL100-1. My phone's battery so fast finishes and not working camera. Serviceman said me CPU is broken. I tried find motherboard from internet. But I don't know motherboard name. Please help me where can I buy motherboard and camera? Thanks
Tamir - 回复
THE VIBRATOR AND VOLUME BUTTONS ARE ALL ONE PIECE! Before you can replace the vibrator, you have to unscrew the housing of the volume buttons and take out the whole piece: volume button flex with the housing, vibrator, and flash flex. So in other words, you have to replace the whole thing since in this guide they actually separated the volume flex from the vibrator, rendering it broken.
aerophoenix72 - 回复
"Teardowns provide a look inside a device and should not be used as disassembly instructions."
Interesting, so are there separate "disassembly" instructions?
Anyway, this was very helpful, thanks! I used this guide to replace the bottom microphone. As far as tools I only needed a T3 torx driver and a plastic prying tool.
Nader Zaidan - 回复
Hi, can I dissasembly the body to get simcard reader out without using Torx T2 ? I have a propblem with this part of phone but unfortunately i have only Torx T4
zacnyplebejusz - 回复
according to step 9 an 10 pictures,mainboard used in this teardown is unrepairable....
Nikola Nikolinicic - 回复
I’ve replaced the speaker and jack unit, but still have very low internal speaker sound; not sure what to do about that. I tried a full security wipe and reinstall too, and that didn’t change anything. Starting to think the motherboard has an issue?
Joe Smith - 回复
I’ve got a dead z10 and I think the issue is the charger wires frayed and it shorted out. Any ideas what might have gotten damaged in the phone from this happening and is it repairable? The does nothing at all now; completely dead. No red light or anything at all - no signs of life whatsoever… Thanks for any info!
scottwade - 回复
Any say me were to get 3g housing for blackberry z10
Mitun - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 24
过去的30天: 89
总计 166,446
