在此拆机指南中使用的工具
简介
This thing landed in our laps. We tried it, tested it, and then ripped it apart! All information can be found at www.phonewreck.com.
这个拆解是不是维修指南。 要维修你的的BlackBerry Presenter,请使用我们的维修手册
  1. The BlackBerry Presenter ~$200 Solid Design
    • The BlackBerry Presenter
      • ~$200
      • Solid Design
      • A clever design trick,the Power Button is the Blackberry Logo
  2. Moving around the back, we see all of the ports
    • Moving around the back, we see all of the ports
    • VGA Port
    • S Video Port
    • Micro Usb
    • NTSC/PAl Switch
  3. Peel back the Rubber pad on the bottom of the device.
    • Peel back the Rubber pad on the bottom of the device.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Grab your T7 and poke it through the adhesive pad. Remove the four screws. The top portion of the device should lift free, pretty easily.
    • Grab your T7 and poke it through the adhesive pad.
      • Remove the four screws. The top portion of the device should lift free, pretty easily.
  6. There's the PCB! Now to get under it..
    • There's the PCB! Now to get under it..
  7. Grab a small wrench  or a pair of pliers and remove the screws holding in the VGA port.
    • Grab a small wrench or a pair of pliers and remove the screws holding in the VGA port.
  8. Focus Enchancments : FS455LF   0731 kox4h00  is a TV encoder designed for applications which require Component Video, VGA, or RGB output capabilities.It can accept digital video or computer graphics in many different resolutions and rates, and convert them to high quality analog video. TI TMS320 DM350ZWX
    • Focus Enchancments : FS455LF 0731 kox4h00 is a TV encoder designed for applications which require Component Video, VGA, or RGB output capabilities.It can accept digital video or computer graphics in many different resolutions and rates, and convert them to high quality analog video.
    • TI TMS320 DM350ZWX
    • ST microelectronics
drwreck
于2009年11月11日注册
1,432 信誉积分
创作了11篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 3
总计 5,697
