跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的BlackBerry 8700c,请使用我们的维修手册
  1. BlackBerry 8700c Teardown, BlackBerry 8700c Teardown: 步骤 1 中的图像 1,1
    • In this first step you will remove the battery cover by pushing down on the button on the cover and sliding towards the bottom of the phone.
    • To do this unscrew all four T6 screws
    • Once this is done gently remove the back cover of the phone by pulling first from the bottom towards you, then from the top upwards.
  2. BlackBerry 8700c Teardown: 步骤 2 中的图像 1,1
    • To remove the battery, place your fingernail in the slot at the top right of the battery and pull up.
  3. BlackBerry 8700c Teardown: 步骤 3 中的图像 1,3 BlackBerry 8700c Teardown: 步骤 3 中的图像 2,3 BlackBerry 8700c Teardown: 步骤 3 中的图像 3,3
    • Next, remove the back portion of the phone by removing four T6 Screws.
    • Once the screws have been removed, firmly grab the back cover and pull back from the front cover.
  4. BlackBerry 8700c Teardown: 步骤 4 中的图像 1,2 BlackBerry 8700c Teardown: 步骤 4 中的图像 2,2
    • To remove the middle portion of the phone you will again remove four T6 screws.
    • Follow the removal of the screws, you can now pull the front face plate away from the middle portion.
  5. BlackBerry 8700c Teardown: 步骤 5 中的图像 1,2 BlackBerry 8700c Teardown: 步骤 5 中的图像 2,2
    • Follow the removal of the screws, you can now pull the middle portion away from the main logic board.
    • Next, hold the logic board and remove the front face plate of the phone
  6. BlackBerry 8700c Teardown: 步骤 6 中的图像 1,2 BlackBerry 8700c Teardown: 步骤 6 中的图像 2,2
    • When the front face plate has been pulled away, be sure to grab the keypad as it may fall out.
  7. BlackBerry 8700c Teardown: 步骤 7 中的图像 1,2 BlackBerry 8700c Teardown: 步骤 7 中的图像 2,2
    • Next, use a metal spudger to unhook the earpiece from the inside of the front panel.
  8. BlackBerry 8700c Teardown: 步骤 8 中的图像 1,3 BlackBerry 8700c Teardown: 步骤 8 中的图像 2,3 BlackBerry 8700c Teardown: 步骤 8 中的图像 3,3
    • Using a metal spudger, push back on the four clips holding the LCD screen to the logic board.
    • Next gradually pull the screen away from the board so that none of the clips are engaged.
    • Last, use a metal spudger to push back on the clip locking in the ribbon cable for the screen.
  9. BlackBerry 8700c Teardown: 步骤 9 中的图像 1,1
    • The screen is now fully detached, and the phone is completely disassembled.
k3nt
于10/28/09注册
42 声望
创作了4篇指南
团队
Cal Poly, Team 18-4, Maness Fall 2009 Cal Poly, Team 18-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S18G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 6,547
