跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Belkin Express Dock,请使用我们的维修手册
  1. Belkin Express Dock Teardown, Belkin Express Dock Teardown: 步骤 1 中的图像 1,1
    • View of the connectors
  2. Belkin Express Dock Teardown: 步骤 2 中的图像 1,2 Belkin Express Dock Teardown: 步骤 2 中的图像 2,2
    • Use a putty knife to remove the four rubber feet. Once removed, there are 4 phillips screws to be removed.
  3. Belkin Express Dock Teardown: 步骤 3 中的图像 1,1
    • The next step is to use the putty knife to pry off one of the two plastic endcaps, they snap out and the circuit board slides out.
  4. Belkin Express Dock Teardown: 步骤 4 中的图像 1,1
    • Use the phillips screwdriver to remove 5 more screws to remove the plastic mounting frame.
  5. Belkin Express Dock Teardown: 步骤 5 中的图像 1,2 Belkin Express Dock Teardown: 步骤 5 中的图像 2,2
    • Front and back of the board.
    • From left to right on the front of the board the major chips are: LSI FW643E-02 (FIreWire800); Broadcom BCM57762 (gige); Intel L150I56 (Thunderbolt controller), NXP LPC1114F (two), Fresco FL1100 (USB3); C-Media CM119A (Audio)
    • From left to right on the back of the board the major chips are: Parade PS161HDM; Parade PS8301 (two); NXP ZSD310 (two); Parade PS8321. The chips seem to support HDMI/DVI conversion and Display Port!
  6. Belkin Express Dock Teardown: 步骤 6 中的图像 1,3 Belkin Express Dock Teardown: 步骤 6 中的图像 2,3 Belkin Express Dock Teardown: 步骤 6 中的图像 3,3
    • close-ups of the major chips
thompsonfamily
于01/21/11注册
217 声望
撰写一个指南
2条评论
Hi… someone have the board scheme, please?
My express dock only flashing the Led when I plugged the power cord and turn off
Anderson Galdino - 回复
I cannot get any power going into the dock. I was wondering if anyone has had any experience with the analog board and dead power. The cables are hot so I know it must be the dock itself. Just nothing. Its internal leds do not light up and the Ethernet port has no activity lights either.
Any advice would be welcome.
airira - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 35
总计 6,292
