跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Asus ZenWatch 3,请使用我们的维修手册
  1. Asus ZenWatch 3 Teardown, Let's begin: 步骤 1 中的图像 1,1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: 步骤 2 中的图像 1,2 Asus ZenWatch 3 Teardown, Band Removal: 步骤 2 中的图像 2,2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: 步骤 3 中的图像 1,1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: 步骤 4 中的图像 1,1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: 步骤 5 中的图像 1,1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: 步骤 6 中的图像 1,1
    • Battery
  7. Asus ZenWatch 3 Teardown: 步骤 7 中的图像 1,1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: 步骤 8 中的图像 1,1
    • Complete disassembly
Reon
于02/01/13注册
141 声望
撰写一个指南
20条评论
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - 回复
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - 回复
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - 回复
What should I do if the power button doesn’t work?
MichaelKing10or - 回复
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 47
总计 14,426
