跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Asus Transformer Pad Infinity,请使用我们的维修手册
  1. Asus Transformer Pad Infinity Teardown, Asus Transformer Pad Infinity Teardown: 步骤 1 中的图像 1,1
    • This Transformer Pad Infinity has crossed the wrong desk and is about to be torn asunder. Let the Games Begin!
    • First, turn the power off :)
  2. Asus Transformer Pad Infinity Teardown: 步骤 2 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 2 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 2 中的图像 3,3
    • Insert a small flat head screwdriver into the 2 docking station guide ports on the bottom of the tablet.
    • There is a small tab inside the bottom of the port. Use your screwdriver to push the tab to the right until it clicks. This unlocks the bottom tabs that hold the screen to the casing.
    • If you have successfully unlocked it, you should see a small arrow in the bottom of the port that points to the left. This indicates which way to push the tab to relock the tabs during re-assembly.
    • Be sure to unlock the tabs in both docking station guide ports.
    Put the head of your small screwdriver into the small, almost circular hole in the tab, and push hard to the right.
    christopher - 回复
  3. Asus Transformer Pad Infinity Teardown: 步骤 3 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 3 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 3 中的图像 3,3
    • Here is a look at the locking assembly that you disengaged during Step 2.
    • Next, use your spudger or other opening tool to push upward (towards the screen) on the small plastic tabs that are located on the top of the docking station guide ports. This should push the screen away from the frame and provide you enough room to insert the flat side of another spudger to start freeing the bottom of the screen from the case.
    • Work the flat end of your spudger along the bottom edge of the tablet to disengage the plastic tabs from the locking mechanism inside.
    Great write up.
    On step 3.2 - I found a credit card to work effectively without damaging the locking tabs. Starting from the bottom near docking ports, slide card under screen and work your way around. No scratches, no damages tabs
    BAD - 回复
    Great recommendation! I would like to add that you should angle your credit card (or used-up gift card) to be as normal to the screen (90 degrees) as possible when sliding the card around the sides. You are trying to push the aluminum case away from the screen edge for a smooth release.
    Skroob -
    Hi Did any one tear down the keyboard?
    Peter Lye - 回复
  4. Asus Transformer Pad Infinity Teardown: 步骤 4 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 4 中的图像 2,2
    • Next, use your spudger to pop open the plastic tabs located on either side of the tablet. There are 4 tabs on each side located in the same position on each side.
    • BE CAREFUL! These tabs are fairly fragile. I managed to break just about every one of them on my tablet :(
    • I think the safest way to open them is to apply light pressure to the case and pry it away from the screen until the tab pops free (not just rip it open like I did.)
    • You should now be able to hinge the screen open along the top edge then disengage it completely from the body.
  5. Asus Transformer Pad Infinity Teardown: 步骤 5 中的图像 1,1
    • There is an internal power switch next to the battery connector, that will kill power to the entire device while you're working on it.
    • Don't forget to switch it back on when you're reassembling!
  6. Asus Transformer Pad Infinity Teardown: 步骤 6 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 6 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 6 中的图像 3,3
    • Now that the hard part is done, lets see some guts.
    • Use your spudger to release the 2 digitizer ribbon cables from the mainboard. They are located on the left side of the tablet between the micro-HDMI and the microSD slot.
    • Use your spudger to release the LCD cable from the back of the LCD.
    • You should now be able to separate the screen assembly from the body of the tablet. Set it aside for later disection.
  7. Asus Transformer Pad Infinity Teardown: 步骤 7 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 7 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 7 中的图像 3,3
    • The inside of your tablet will more than likely look less battle scarred than mine at this point. I decided to take my photos during the re-assembly stage - thus all the scars.
    • To remove the front facing camera (right,) use your spudger to unlock the ribbon cable and slide the camera out.
    • To remove the rear facing camera (left,) unplug it from it's socket by applying light lifting pressure to the back of the cable.
    • Remove the backup battery on the right side by unplugging the cable from the motherboard with your spudger and then prying it out. It is glued down lightly with adhesive.
    This thing is not a backup battery, it is the vibration motor / crystal, my TF700 was "vibrating" for long periods of time, I teared it down, removed it, turned it on again and the all the vibration was gone (even those that were ok, like moving from sound to vibration).
    Emerson Jr - 回复
  8. Asus Transformer Pad Infinity Teardown: 步骤 8 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 8 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 8 中的图像 3,3
    • We can now remove the motherboard, daughterboard, and dock connector by removing 14 screws.
    • Be sure to unplug the speaker plug from the motherboard before removing it.
    • Flip The motherboard from the top edge of the tablet down (towards the battery) to reveal the battery connector. Unplug it with light pressure from your spudger.
    • Then disconnect the motherboard from the daughterboard by unlocking the ribbon cable on the back side of the daughterboard.
  9. Asus Transformer Pad Infinity Teardown: 步骤 9 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 9 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 9 中的图像 3,3
    • To remove the battery, remove the 8 screws then work your spudger underneath the battery between the 2 cells to work it free of the adhesive that fastens it to the case.
  10. Asus Transformer Pad Infinity Teardown: 步骤 10 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 10 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 10 中的图像 3,3
    • To remove the speaker, simply work your spudger underneath it and work it free of the adhesive that holds it to the case.
    • To remove the bottom screen attachment locking mechanism, remove the 8 screws and lift the pieces out.
  11. Asus Transformer Pad Infinity Teardown: 步骤 11 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 11 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 11 中的图像 3,3
    • Now that we're left with a boring empty shell, let's return to the LCD assembly that we set aside in Step 5.
    • Remove the 4 screws. Then work your spudger underneath the edges of the LCD to separate it from the Gorilla Glass front. It has a light adhesive around all edges.
  12. Asus Transformer Pad Infinity Teardown: 步骤 12 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 12 中的图像 2,2
    • With the LCD free, you should now be able to lay it out in a big pile of parts and the teardown is complete. Now let's see what's under all those heatsinks and tape.
  13. Asus Transformer Pad Infinity Teardown: 步骤 13 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 13 中的图像 2,2
    • The back side of the motherboard offers very little of interest...
  14. Asus Transformer Pad Infinity Teardown: 步骤 14 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 14 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 14 中的图像 3,3
    • ...but here's some close-ups anyway.
  15. Asus Transformer Pad Infinity Teardown: 步骤 15 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 15 中的图像 2,2
    • The front side of the motherboard is where all the action is.
    • Tegra 3 quad core processor T33-P-A3
    • 2x Elpida memory J4216EBBG-GNL-F
    • Realtek? ALCS631
    • Hynix H26M64002BNR e-NAND
  16. Asus Transformer Pad Infinity Teardown: 步骤 16 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 16 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 16 中的图像 3,3
    • And some closeups.
  17. Asus Transformer Pad Infinity Teardown: 步骤 17 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 17 中的图像 2,2
    • Front and back of the daughterboard.
  18. Asus Transformer Pad Infinity Teardown: 步骤 18 中的图像 1,2 Asus Transformer Pad Infinity Teardown: 步骤 18 中的图像 2,2
    • The back of the LCD.
  19. Asus Transformer Pad Infinity Teardown: 步骤 19 中的图像 1,3 Asus Transformer Pad Infinity Teardown: 步骤 19 中的图像 2,3 Asus Transformer Pad Infinity Teardown: 步骤 19 中的图像 3,3
    • Close-ups.
    • That's all I've got. I apologize for any blurry pics as all I had on hand was my cell phone ( <3 Samsung Galaxy Note.) I hope your teardowns are far less destructive than mine was. Good Luck.
    • ...and yes, it still works after reassembly. Thanks for asking.
Matt
于08/29/12注册
497 声望
撰写一个指南
33条评论
Does anyone know what the internal on/off switch does on the motherboard? Right next to the battery connector. How can you see that in a tear down and not mention it?
Jcortes1982 - 回复
It is a master on/off switch. When the switch is flipped to the off position, the tablet will not operate. You can see the switch labels on the second picture of Step 13.
Matt -
Ya its for when your doing work inside the tablet your supposed to flick that off so you dont accidentally short anything. Like the on/off switch on your power supply on the back of your desktop
Jon Pileot -
Thanks for this teardown! Could the "mushy" power / volume buttons be due to poor placement of the buttons / board? Could slight nudging of the board in one direction or the other help the "mushy" buttons?
Jon Pileot - 回复
Hi there, thank you very much for this teardown. I wanted to inquire if you were able to find out anything about the gyroscopes/accelerometers/GPS and other sensors during this. I'm doing a project and this would be very helpful information.
Johnathon - 回复
Thanks so much for answering that. I did see that it was labelled "on/off" but wasn't sure what it switched. The best guess I could come up with was to completely override the cameras, like a factory set feature for corporate/gov purchases. Your answer makes much more sense.
Jcortes1982 - 回复
There were severel TF 700 sold which show a not completely fixed display. In one ore more positions of the display you can press it slighty inwards and it "creaaks"
After seeing the broken tabs in step 4 I think that these tabs could also break during assembling in the factory. That would explain the creaking display. I wonder how they do it for repair at ASUS service if the tabs were that fragile (provided they have a service ;) )
Michael - 回复
Does anyone where the motor for the haptic feedback and why it might make a clicking sound? I am thinking about tearing down my tf700 if it's just a matter or reseating the motor.
o0oelkabongo0o - 回复
May I ask you what you have done about the broken tabs? Are there any spare parts available in any online store?
Michael - 回复
Where can I find an LCD screen to replace my broken one. I just got my Asus Infinity Tablet the end of October and already dropped it
Brenda - 回复
hey do you think it is possible to purchase elpida ram chips and increase the ram on the tablet? would be aweesome to have even 2 gb ram on this thing!
Andrew - 回复
thanks
it looks like if you need to replace a SD card slot you will have to replace the complete daughter board, with several slots on it. do the usual warranty cover such cost?
sunny - 回复
Great work with this teardown! Kudos and thanks. But while we are here has anyone found a place to purchase a battery for the Asus TF 700? I have spent hours searching and nothing so far!
Wayne - 回复
Hi, in the Step 5, exactly, how to do to release the 2 digitizer ribbon?
Should I lift the piece of black color by the front or back?
or Should I slide the piece of black color?
Gonzalo Chacon - 回复
You very gently lift the black tab from the ribbion side. If the black tab doesn't lift very easily, examine it very closely for about an hour. After careful consideration of how the piece may have been engineered, you could try to gently slide it towards the ribbion. If the black bar did manage to slide you should lift it gently up off of the ribbion. As you slide ribbion out take note of which way the contacts are facing if you plan on reassembling your device later.
mark -
Actually you lift ever so gently on the white half- to the rear of where the cables insert. Those things are so easy to break, & impossible to replace
Joseph Settergren -
Like Wayne I have been searching long & hard for a replacement battery. I even got ripped off by an eBay seller who listed a "NEW OEM" battery that looked like it had been run over by a truck! Does anyone know of a reasonably priced source for these batteries? Thanks! I
danpobrien - 回复
I have seen many post about the TF700T wont lock into the dock any more, while you had it open could you see what might be the problem. Thanks and Thanks for a great guide.
Robert Crother - 回复
Just replaced my battery (now available on eBay for around $25), and I only had to go to step 3, wiggle the old battery out, the new one in, and reverse, way easier than expected, thanks for the awesome write up! In order to avoid breaking tabs (I didn't break one, yay), using a good metal spudger (high quality, worth every penny, way thinner and stronger, and I haven't had an issue with scratching yet), and when you are separating the display from the case, pry the aluminum case outwards with one spudger while lifting the display glass up with the other. Comes out in about a minute easily. Thanks again for blazing the trail, especially the warning about the tabs, I may have given up and sold the thing as broken otherwise.
Mike Craft - 回复
I have a TF700t which has broken the charging/data connection between the tablet and docking station. I had been unable to lock the docking station in place for some time which led to the screen getting cracked when the unit was closed and in a bad but came loose. This has also led tho the charging connection breaking. The tablet was connected to the docking station and closed but was knocked off a desk. The fall broke both connectors in the tablet and the docking station.
Can anyone suggest how I might find replacement parts?
Sarah - 回复
Hi Guys. I used this to help me replace a digitizer. the first time, I didn't realise the machine was on and shorted out my LCD screen (which had been undamaged!! After getting a new screen and cable, I have connected it all, but now find that the backlight works on the LCD but not the image!!! Is this an issue with the cable or the screen? Thanks, Nick
Nick Barr - 回复
Hi Nick, I'm having this same issue. Did you ever find what the problem was?
Steve -
i cant turn it on, only vibrating after 10-15 sec, when i plugged the charger tle light were green but nothing happens, i cant turn it on . help
tirolvlasic - 回复
HI. I ve had a problem since the first 40 days with my TF700. The screeen would blank out randomly. It looks like a bad connection because when i press the screen close to the bottom of the unit the image would come back. I dont loose light, just the image. Even when blanked out , you could see that the screen was lit. I didnt sent it to repairs because i bought it when i was in Canada and found out (SURPRISINGLY) that ASUS is not covering worldwide warranty (Lost some major points on my future buys). So recently (ive been able to use it for 14 months that way, not so troublesome), i sent it to a local repair store. After 25 days the guy called me back to get the tablet saying he was not able to make it work. The bad thing is it doesnt work at all now.
Andre De Marco - 回复
I oppend it up very easily using the tutorial and found out the 2 side ribbons were disconnected and the one close to the bottom (the LCD ribbon cable) had no docking unit anymore and it was linked up wire by wire with welding wires. Two of them were acctualy broke. So, i relocated the side ribbons (digitizer ?) and i cant do the wire welding myself. Its not working as i imagined- i can feel the vibrattion when it turns on , but no image at all. So the question, can the locking case for the ribbon be replaced ? if not, can it work with the proper wire weldings ?
Andre De Marco -
Can you insert a sim card anywhere?
ERIK - 回复
Hi, thank you for this write up. I have a Asus vivotab smart and I'm considering to try upgrade the internal storage. On yours, were you able simply pry off the storage chip, or was it soldered on? One more question you might know, will the new micro sdxc 128gb or 256gb work in the vivotab smart? Thanks
Ray F, 15-12-2014
rafbus - 回复
I have a brick 700, I was tool to replace logic board. Would that be the motherboard?
Also can you upgrade memory from 16 to 32gb ?
John Buyher - 回复
Thank you very much for this writeup. TF700t had gone into a very deep sleep and would not power on although I did notice amber light when it was discharged after a month long out of country visit and a green followed by a full charge. It needed the first 3 steps here and little internal power switch helped resolve issue (discharge and power on)
Upendra Gandhi - 回复
My TF700 turns on, but I cannot launch apps, then after several seconds, it turns off and recycles into the start process. Once it gets into that loop, it will not turn off, until battery dies. Is there a fix? If not, how can I get my photo's etc?
Jesus Cruz - 回复
There are 2 small rectangular rubber spacers. Do you know where they go? Could not tell by the pics. Thanks. Great teardown.
Steve Griffith - 回复
As I was jiggling the battery loose from the adhesive I accidentally disconnected the charging cable from the Motherboard, and can not figure out how to reconnect it. It appears to be connected on the underside, but I can't see a socket or locking mechanism to hold it secure.
Joe Lombardo 207-2017
Joe Lombardo - 回复
Previous comment I was able to remove Mother Board assembly and reconnect docking/charging cable, and actually get it back together, with the exception of a small rectangular rubber bumper which fell out from somewhere? But on the plus side new battery charged fully and I was amazed, LOL downside is the touch screen will not respond now. Tried the cold start and reopened case and checked digitizer cables and also LED cable but all were connected solidly. Any suggestions? for getting touch screen to respond. Before teardown and battery replacement all was working well, just old battery was not holding charge for long? Thanks for any help
Joe Lombardo
Joe Lombardo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 100,003
