跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Asus Chromebit CS10,请使用我们的维修手册
  1. Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: 步骤 1 中的图像 1,3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: 步骤 1 中的图像 2,3 Asus Chromebit CS10 Teardown, Asus Chromebit CS10 Teardown: 步骤 1 中的图像 3,3
    • The top image is the Chromebit with dust cap on its box next to a standard Sharpie for scale.
    • The circled screw in the second image is the write-protect screw, if you remove this and reassemble the Chromebit, if you boot in Developer Mode you are able to unlock the software write-protect and modify/replace the system firmware.
    • Using an iFixit spudger in the USB port stand it up to increase the gap to the sides of the USB port where you can insert a second spudger or a guitar pick and run it down each of the sides of the Chromebit to pop the case loose.
dragon788
于08/20/16注册
708 声望
创作了3篇指南
团队
ComputerPhreaks ComputerPhreaks 的会员
Business
1 名成员
创作了3篇指南
2条评论
How did you get this open? I’ve been using the spudger with out any luck. Is the case glued on by any chance? Thanks
Jimbo - 回复
If you turn the end of the spudger sideways to get it started you should be able to undo the clips around the edges with a guitar pick. There is some resistance from the thermal pad.
dragon788 -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 1,589
