跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Apple Universal Dock Model A1256,请使用我们的维修手册
  1. Apple Universal Dock Model A1256 Teardown, Apple Universal Dock Model A1256 Teardown: 步骤 1 中的图像 1,1
    • Pry along the edge of the bottom of the case. It will just pop out.
  2. Apple Universal Dock Model A1256 Teardown: 步骤 2 中的图像 1,1
    • Remove the top case from the bottom.
  3. Apple Universal Dock Model A1256 Teardown: 步骤 3 中的图像 1,1
    • There are five Phillips screws holding the metal brace down (In the picture I have already removed them).
  4. Apple Universal Dock Model A1256 Teardown: 步骤 4 中的图像 1,2 Apple Universal Dock Model A1256 Teardown: 步骤 4 中的图像 2,2
    • The brace is glued in near the ir-sensor. You may have to apply a little bit force to remove it, but it will come out with just pulling. (You can pry it a little bit with a spudger or a screwdriver)
  5. Apple Universal Dock Model A1256 Teardown: 步骤 5 中的图像 1,2 Apple Universal Dock Model A1256 Teardown: 步骤 5 中的图像 2,2
    • The only major chip located on the circuit board. (All those who have wondered about the dock's line out, I think we are clear now.)
Devilac
于06/23/10注册
67 声望
撰写一个指南
一条评论
Can the actual dock insert (the section the iPod would clot on top of) be used in an Apple iPod HiFi repair? (see repair article Apple iPod Hi-Fi iPod Dock Inserts Replacement)
Harrison C - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 40
总计 24,644
