跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Apple Studio Display M2454,请使用我们的维修手册
  1. Apple Studio Display M2454 Teardown, Apple Studio Display M2454 Teardown: 步骤 1 中的图像 1,1
    • Notice that the main components of the monitor are only accessible from the back of the device.
  2. Apple Studio Display M2454 Teardown: 步骤 2 中的图像 1,1
    • Locate the four hex head screws located on the corners of the back panel.
    • Remove the screws with a 2mm hex screwdriver.
  3. Apple Studio Display M2454 Teardown: 步骤 3 中的图像 1,1
    • Remove the clear and gray back panels.
  4. Apple Studio Display M2454 Teardown: 步骤 4 中的图像 1,1
    • Remove the three screws with #2 phillips head screwdriver.
  5. Apple Studio Display M2454 Teardown: 步骤 5 中的图像 1,1
    • To remove the metal panel, push towards the bottom of the monitor to release its clips and pull the panel away.
  6. Apple Studio Display M2454 Teardown: 步骤 6 中的图像 1,1
    • Remove screw holding the plastic bracket with #2 Phillips head screwdriver.
  7. Apple Studio Display M2454 Teardown: 步骤 7 中的图像 1,1
    • Remove the four screws on the metal bracket.
  8. Apple Studio Display M2454 Teardown: 步骤 8 中的图像 1,1
    • Remove the two philips head hold-down screws with the #2 Phillips head screwdriver.
  9. Apple Studio Display M2454 Teardown: 步骤 9 中的图像 1,1
    • Remove black connector by pushing the end of the tab closest to the wiring and pulling away from board.
  10. Apple Studio Display M2454 Teardown: 步骤 10 中的图像 1,1
    • Remove white connector by lifting tab and pulling away from board.
    • Be careful when lifting tabs, they break easily.
  11. Apple Studio Display M2454 Teardown: 步骤 11 中的图像 1,1
    • Remove connector connected to the hold down previously removed simply by pulling with hand.
  12. Apple Studio Display M2454 Teardown: 步骤 12 中的图像 1,1
    • Now that the main computer cable is detached, remove it away from monitor.
  13. Apple Studio Display M2454 Teardown: 步骤 13 中的图像 1,1
    • Remove the two screws holding the USB port in place with #2 Phillip's head screwdriver.
  14. Apple Studio Display M2454 Teardown: 步骤 14 中的图像 1,1
    • Remove the screw on the wire hold down with #2 Phillips head screwdriver.
  15. Apple Studio Display M2454 Teardown: 步骤 15 中的图像 1,1
    • Remove white connector connected to LCD main board by lifting tab with tool and pulling away from board.
  16. Apple Studio Display M2454 Teardown: 步骤 16 中的图像 1,1
    • The USB port is now detached, remove it from monitor.
  17. Apple Studio Display M2454 Teardown: 步骤 17 中的图像 1,1
    • Remove connector on the left bottom corner of the LCD main board by simply pulling with hand.
  18. Apple Studio Display M2454 Teardown: 步骤 18 中的图像 1,1
    • Remove the connector on the bottom right corner by 1st removing tape first and pulling with hand.
  19. Apple Studio Display M2454 Teardown: 步骤 19 中的图像 1,1
    • Remove top right connector of the LCD main board by pulling with hand.
  20. Apple Studio Display M2454 Teardown: 步骤 20 中的图像 1,1
    • Remove the final connector of the LCD main board by pulling with hand.
  21. Apple Studio Display M2454 Teardown: 步骤 21 中的图像 1,1
    • Remove the four screws on each corner of the main board with #2 Phillips head screwdriver.
  22. Apple Studio Display M2454 Teardown: 步骤 22 中的图像 1,1
    • The board is now detached, remove it from monitor.
  23. Apple Studio Display M2454 Teardown: 步骤 23 中的图像 1,1
    • Locate the top and bottom connector on the CCFL inverter and remove it by inserting pin into the small holes and pulling away.
    • This step may be easier with two people.
  24. Apple Studio Display M2454 Teardown: 步骤 24 中的图像 1,1
    • Remove the two screws on the top and bottom of the CCFL inverter with #2 Phillips head screwdriver.
  25. Apple Studio Display M2454 Teardown: 步骤 25 中的图像 1,1
    • The CCFL inverter is now detached, remove it from monitor.
  26. Apple Studio Display M2454 Teardown: 步骤 26 中的图像 1,1
    • You have now successfully taken apart a Apple Studio Display M2454.
Dylan Perry
于01/20/10注册
177 声望
创作了5篇指南
团队
Cal Poly, Team 13-27, Maness Winter 2010 Cal Poly, Team 13-27, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G27
4 名成员
创作了9篇指南
3条评论
This model is also known as the Apple Studio Display 15" LCD.
analogcd - 回复
excellent wee guide......i came here in my search for a replacement stand for this model.
bobby nailen - 回复
Failing caps were the main problem with this — no air flow.
Mal - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 7,645
