跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Apple Magsafe Power Adapter,请使用我们的维修手册
  1. Apple Magsafe Power Adapter Teardown, The Power Adapter: 步骤 1 中的图像 1,1
    • Here is the product that will be the focus of the teardown.
  2. Apple Magsafe Power Adapter Teardown, Top Case Removal: 步骤 2 中的图像 1,1
    • One part of the outer casing (referred to as the top part of the case) is removed revealing an aluminum wrapping.
  3. Apple Magsafe Power Adapter Teardown, Unwrapping: 步骤 3 中的图像 1,2 Apple Magsafe Power Adapter Teardown, Unwrapping: 步骤 3 中的图像 2,2
    • Unwrapping the aluminum allows the internal components to be accessed.
    • The aluminum and the 3M film shown act as a heat sink and EM shield for the internal components.
  4. Apple Magsafe Power Adapter Teardown, Bottom Case Removal: 步骤 4 中的图像 1,2 Apple Magsafe Power Adapter Teardown, Bottom Case Removal: 步骤 4 中的图像 2,2
    • The second half of the outer casing is removed to isolate the board. Note the white paste on the board used to thermally isolate the components.
    • The second picture shows the bottom of the circuit board (left) after removing the support (right). Here, too, we see use of paste but for the purpose of binding the support and circuit.
  5. Apple Magsafe Power Adapter Teardown, Paste Removal: 步骤 5 中的图像 1,1
    • The paste can be picked off of the board to get a better look at the circuit components it covers up.
  6. Apple Magsafe Power Adapter Teardown, Another Angle: 步骤 6 中的图像 1,1
    • The large capacitor on the circuit board can be bent upright to show more components underneath it.
Mauricio Gomez
于03/08/18注册
173 声望
撰写一个指南
2条评论
Fixed loads of these - usually the startup cap, but I always check/replace all the caps.
Mal - 回复
pretty good for your first guide! I would recommend getting a counterfeit charger and compare it with a genuine one.
Aiden - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 33
总计 8,929
