跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Anker LC-90 Rechargeable Flashlight,请使用我们的维修手册
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: 步骤 1 中的图像 1,3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: 步骤 1 中的图像 2,3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: 步骤 1 中的图像 3,3
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: 步骤 2 中的图像 1,1
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: 步骤 3 中的图像 1,3 Anker LC-90 Rechargeable Flashlight Teardown: 步骤 3 中的图像 2,3 Anker LC-90 Rechargeable Flashlight Teardown: 步骤 3 中的图像 3,3
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: 步骤 4 中的图像 1,1
    • The Anker LC-90 is now tore down
Nick Wolfe
于01/24/18注册
709 声望
创作了2篇指南
团队
Cal Poly, Team S18-G4, Livingston Winter 2018 Cal Poly, Team S18-G4, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G4
4 名成员
创作了13篇指南
5条评论
cannot buy parts or return
JULIA - 回复
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
JULIA - 回复
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - 回复
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - 回复
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 3,986
