跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的American Era Electric Rice Cooker,请使用我们的维修手册
  1. American Era Electric Rice Cooker Teardown, Rice Cooker Teardown: 步骤 1 中的图像 1,1
    • Start with the rice cooker unplugged, on a flat surface.
  2. American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 步骤 2 中的图像 1,3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 步骤 2 中的图像 2,3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: 步骤 2 中的图像 3,3
    • Remove the lit and pot and turn upside down.
  3. American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 步骤 3 中的图像 1,3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 步骤 3 中的图像 2,3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: 步骤 3 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Remove the bottom plate by lifting one of the rubber feet.
  4. American Era Electric Rice Cooker Teardown, Remove Internal Screws: 步骤 4 中的图像 1,2 American Era Electric Rice Cooker Teardown, Remove Internal Screws: 步骤 4 中的图像 2,2
    • We're inside! Here's our first look at the circuitry. Let's take it apart.
    • Use a 3/8" or 8 mm flathead screwdriver to remove these six screws.
  5. American Era Electric Rice Cooker Teardown, Bend Tab: 步骤 5 中的图像 1,2 American Era Electric Rice Cooker Teardown, Bend Tab: 步骤 5 中的图像 2,2
    • Find the metal tab that connects the center button to the switch lever.
    • Use pliers to bend the metal tab into a U shape.
    • Align the tab with the slot so that it falls through.
  6. American Era Electric Rice Cooker Teardown, Remove Heating Element: 步骤 6 中的图像 1,2 American Era Electric Rice Cooker Teardown, Remove Heating Element: 步骤 6 中的图像 2,2
    • Turn the rice cooker right-side up.
    • Grab the center button and pull the heating plate upward. The gray metal ring should come out with it.
  7. American Era Electric Rice Cooker Teardown, Remove Temp. Sensor: 步骤 7 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the screw connecting the temperature sensor to the heating element.
    • Remove the temperature sensor.
  8. American Era Electric Rice Cooker Teardown, Remove Center Button: 步骤 8 中的图像 1,3 American Era Electric Rice Cooker Teardown, Remove Center Button: 步骤 8 中的图像 2,3 American Era Electric Rice Cooker Teardown, Remove Center Button: 步骤 8 中的图像 3,3
    • Three bent metal tabs connect the center button to the heating element. Use pliers to flatten these three tabs.
    • Remove the center button from the heating element.
  9. American Era Electric Rice Cooker Teardown, Remove Control Panel: 步骤 9 中的图像 1,2 American Era Electric Rice Cooker Teardown, Remove Control Panel: 步骤 9 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the screw that secures the control panel.
    • Remove the control panel from the outside of the rice cooker.
  10. American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 步骤 10 中的图像 1,3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 步骤 10 中的图像 2,3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: 步骤 10 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the screw securing the rectangular fiberglass plate. This should free the two light bulbs.
    • Use a Phillips #1 screwdriver to remove two screws securing the switch lever to the control panel plate. Remove the switch lever.
  11. American Era Electric Rice Cooker Teardown, Disassemble Switch: 步骤 11 中的图像 1,2 American Era Electric Rice Cooker Teardown, Disassemble Switch: 步骤 11 中的图像 2,2
    • Use pliers or hex wrench to hold the nut while using a Phillips #1 screwdriver to remove the screw holding the switch assembly together.
    • Pull the switch assembly apart into its parts. Careful not to lose any of these small parts!
  12. American Era Electric Rice Cooker Teardown, All Done!: 步骤 12 中的图像 1,1
    • And here we have it: a fully disassembled rice cooker.
Travis Taylor
于04/12/13注册
464 声望
创作了5篇指南
团队
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G40
4 名成员
创作了37篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 3,959
