跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Amazon Fire Stick 4k,请使用我们的维修手册
  1. Amazon Fire Stick 4k Remote Teardown, Heat the remote to loosen the glue.: 步骤 1 中的图像 1,1
    • Heat it a lot if you are trying to maintain it in working order because it seems the glue on the clasps was very strong. I probably broke mine taking it apart (but it didn't work anyway so I don't know).
  2. Amazon Fire Stick 4k Remote Teardown, Pry it apart.: 步骤 2 中的图像 1,2 Amazon Fire Stick 4k Remote Teardown, Pry it apart.: 步骤 2 中的图像 2,2
    • It takes A LOT of force to pry this apart. I'm not sure it's possible without breaking the inside.
  3. Amazon Fire Stick 4k Remote Teardown, Remove the seven motherboard screws.: 步骤 3 中的图像 1,1
    • Very easy to remove with the #0 phillips screwdriver.
  4. Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 步骤 4 中的图像 1,3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 步骤 4 中的图像 2,3 Amazon Fire Stick 4k Remote Teardown, Remove the motherboard and button pad.: 步骤 4 中的图像 3,3
    • Once the screws are removed, all the pieces come out easily.
Nathan Ruffing
于05/24/21注册
593 声望
创作了2篇指南
一条评论
Thanks for the teardown, new firestorm 4k has a couple of screws under the round wheel, but you can pop that off and the remove.
. I used a pair of pliers to just rip off the mic, it is surface mounted and comes away with the pads and remote still works. Small amount of glue on the inside.
Scott - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 53
总计 3,558
