本篇指南是分解流程而非维修指南 。 如果您要维修您的Amazon Echo Spot,应参考我们的维修指南 。
Remove Bottom Plate. It's a sticker, thicker than you expect. Pry hard.
One T8 screw prevents the screen from rotating, remove this prior to twisting the screen out. Two T5 screws hold the electronics stack.
There is a Micro USB port hiding in the back under a plastic cover.
Attaching a USB cable to the port reveals a device that classifies itself as an "Android Device"
It is also possible by holding down all 3 buttons on the top to put the device into FASTBOOT mode. Lots more to explore here.
After removing the aforementioned T8 screw, press your palm against the screen and twist counterclockwise. Alternately, hot-glue the screen to the workbench, twist the back off, then remove the glue.
Chips
MediaTek MT8163V - Quad ARM Cortex-A53 System on a Chip
GOODIX GT5668 - Touchscreen Controller
Cypress CYW43569 - 802.11 a/b/g/n/ac Bluetooth 4.1
MediaTek MT6323LGA - PMIC
Micron MT52L512M32D2PF-107 WT D9SSF - 16Gbit LPDDR3 SDRAM
SK hynix H26M41208HPR - 8GB NAND
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
