跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Amazon Echo Dot,请使用我们的维修手册
  1. Amazon Echo Dot Teardown, Amazon Echo Dot Teardown: 步骤 1 中的图像 1,2 Amazon Echo Dot Teardown, Amazon Echo Dot Teardown: 步骤 1 中的图像 2,2
    • If Amazon ever ventures into the canned tuna fish business, they'll have a great package design ready to go. In the meantime, the Dot contains some tasty morsels:
    • Dual-band, dual-antenna 802.11 a/g/b/n Wi-Fi with MIMO
    • Alexa Voice Search
    • 7-microphone array
    • Light ring volume adjustment
    • Bluetooth 4.0 for sending and receiving audio
    • 3.5 mm audio output for external speakers
  2. Amazon Echo Dot Teardown: 步骤 2 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 2 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 2 中的图像 3,3
    • Topside, the Dot looks exactly like its older brother, the Echo, complete with its action and mic mute buttons, light ring, volume ring, and microphone array.
    • The Echo scored a respectable 7 out of 10 on the repairability scale, so we're hopeful these design similarities bode well for the Dot.
    • Things are a little different down below, where we're greeted by a rubber cover and some labeling—and not much else.
    • Amazon bestows the Dot with a new model number: S04WQR.
    • Our pals at Creative Electron were good enough to do a little recon work for us and sent over this X-ray image of the Dot. But a mysterious dense object seems to be obscuring much of the view. What did Amazon put in there?
  3. Amazon Echo Dot Teardown: 步骤 3 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 3 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 3 中的图像 3,3
    • For a more exacting visual comparison, we dug up an original Echo.
    • And by "dug up," we mean we grabbed it from the corner of the teardown table, where it has been faithfully serving up groovy repair tunes ever since we reassembled it.
    • Since the Dot is designed to work with your existing speakers, it doesn't need the Echo's sophisticated downward-firing speaker system (or the space and weight that goes with it). So with the first stage separated, we're left with this tiny crew capsule.
    • TL;DR: it looks like Amazon pretty much just chopped out the middle of the old Echo. Neat!
    Not at first. 1st gen dots (what I searched when looking for this) have no volume dial and are held together with 4 screws. Putting the thing back together requires a large exercise in patience trying to align the 4 screw holes for everything inside and not damage the copper ribbon in the middle.
    Genesis - 回复
  4. Amazon Echo Dot Teardown: 步骤 4 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 4 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 4 中的图像 3,3
    • We peel away the grippy rubber pad, fully expecting to find our first screws—but instead, we're greeted by glue. Boo!
    • We'd like to report that the lower case simply clips in place, but when the first opening pick fails to pop it free, we insert another. And another. And another.
    • Yep—it's glued, too.
    • We wrestle it free eventually, but so far the Dot is off to a decidedly less friendly start than its older sibling.
  5. Amazon Echo Dot Teardown: 步骤 5 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 5 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 5 中的图像 3,3
    • Our first look inside reveals what sophisticated tech insiders will instantly recognize as a big metal thing.
    • This steel plate appears to be the culprit behind our somewhat frustrated first X-ray attempt.
    • Fortunately, this metal thing has screws! Some long T6 Torx screws are threaded through the Dot from bottom to top; our driver dispatches them forthwith.
    • Out tumbles the metal thing, with a small speaker riding piggyback.
  6. Amazon Echo Dot Teardown: 步骤 6 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 6 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 6 中的图像 3,3
    • Yep, it's a speaker, albeit a small one. It connects to the Dot by way of a couple pairs of spring contacts.
    • It's not punchy enough for playing music, but it gives Alexa a way to talk back if your other speakers are turned off or disconnected.
    • The speaker is lightly adhered to this shapely blob of steel, which seems to be a simple weight in the base of the Dot. It's likely designed to keep the device planted, so you can twist the volume ring without accidentally spinning your Dot across the table.
    its not working
    zilla abhi - 回复
    The weight is not steel. It’s most likely die-cast zinc alloy.
    Jeff Gormley - 回复
  7. Amazon Echo Dot Teardown: 步骤 7 中的图像 1,2 Amazon Echo Dot Teardown: 步骤 7 中的图像 2,2
    • With the screws removed, only a thin ribbon cable ties all these layers together. Introducing Amazon Echo Dot: Accordion Edition.
    • At one end lies the motherboard and ports, while a separate board at the other end hosts the volume controls and microphone array. A single cable threads its way through the intervening layers to connect the two boards.
    • We shuffle the layers of plastic and silicon back together temporarily; it's all coming apart soon enough.
    • After tweezing away the ribbon cable, we're ready to inspect the motherboard.
  8. Amazon Echo Dot Teardown: 步骤 8 中的图像 1,2 Amazon Echo Dot Teardown: 步骤 8 中的图像 2,2
    • Chips on one side, ports on the other. Here's what this motherboard is packing:
    • Texas Instruments DM3725CUS100 Digital Media Processor
    • Micron MT46H64M32LFBQ 256 MB (16 Meg x 32 x 4 Banks) LPDDR SDRAM
    • Samsung KLM4G1FEPD-B031 4 GB High Performance eMMC NAND Flash Memory
    • Qualcomm Atheros QCA6234 Integrated Dual-Band 2x2 802.11n + Bluetooth 4.0 SiP
    • Texas Instruments TPS65910A1 Integrated Power Management IC
    • Texas Instruments TLV320DAC3203 Low Power Stereo Audio Codec w/ Headphone Amplifier
    • Texas Instruments TPA2025D1 2 W Class D Speaker Amplifier
    I have a question for those out there in the know, when it comes to streaming music on the likes of Spotify Premium in high quality. My budget is admittedly limited, while trying to achieve within those limits the most satisfying, balanced and detailed sound possible. I currently have a new Audio Pro addon T10 (identical to the C10, but without Wi-Fi integration), connected via a quality auxiliary cable to the Amazon Echo Dot. The C10 was favorably compared to the new Sonos Play 5 by whatHiFi; that gives you a point of reference.
    Now, when streaming Spotify at 320kbps, is the speaker sonically held back by the audio processing of the Amazon Echo Dot, whose built-in DAC is the DAC3203 by Texas Instruments, relative to a potential external DAC? If I go the external route, I want to make sure it is truly worthwhile, as the voice assistant in the Dot is unbelievably convenient for streaming music on the fly.
    Laurent Grenier - 回复
  9. Amazon Echo Dot Teardown: 步骤 9 中的图像 1,2 Amazon Echo Dot Teardown: 步骤 9 中的图像 2,2
    • IC identification, continued:
    • Monolithic Power Systems MP2145GD 6 A synchronous step-down converter
    • Maxim Integrated MAX14585AEVB+ hi-speed USB analog switch
    • NXP Semiconductor NX3L1G3157 SPDT analog switch
    • Texas Instruments LP3985IM5X-3.0 150 mA / 3.0 V LDO regulator
    • Diodes Incorporated 74LVC1G125 single buffer
  10. Amazon Echo Dot Teardown: 步骤 10 中的图像 1,3 Amazon Echo Dot Teardown: 步骤 10 中的图像 2,3 Amazon Echo Dot Teardown: 步骤 10 中的图像 3,3
    • With disassembly nearly complete, we tear into the control wheel. It's a dead ringer for the one we found in the original Echo, complete with its geared encoder wheel.
    • That's just fine by us, since it means at least some replacements parts can likely be shared between the original Echo and the Dot.
    • It also means servicing instructions for one will likely be echoed by the other. All in all, it's a win for fans of repair and bad puns everywhere.
    • We slap the control ring back together just long enough to see the encoder wheel doing its thing.
    • There's just something soothing about gears.
  11. Amazon Echo Dot Teardown: 步骤 12 中的图像 1,2 Amazon Echo Dot Teardown: 步骤 12 中的图像 2,2
    • And buried in the top layer we find another control board, functionally identical to the one we dug up in the original Echo.
    • National Semiconductor LP55231 Programmable 9-Output LED Driver (x4)
    • Texas Instruments TLV320ADC3101 92dB SNR Low-Power Stereo ADC (x4)
    • Diodes Incorporated LMV321SE Single Operational Amplifier
    • Texas Instruments SN74LVC74A Dual Positive-Edge-Triggered D-Type Flip-Flops
    • Diodes Incorporated 74LVC1G14 Schmitt Trigger Inverter
    • Diodes Incorporated 74LVC1G125 Single Buffer (x2)
  12. Amazon Echo Dot Teardown: 步骤 13 中的图像 1,2 Amazon Echo Dot Teardown: 步骤 13 中的图像 2,2
    • Amazon Echo Dot Repairability Score: 6 out of 10 (10 is the easiest to repair)
    • The majority of the device is held together by standard Torx screws.
    • Many components are common to the original Echo, making it easier to source parts.
    • The rubber foot, base cap, and speakers are held in place with tough adhesive.
    • The headphone jack and USB port, two common points of failure, are soldered directly to the motherboard.
    my dot no longer works as it got rained on pretty good. i guess i gotta toss it. poop.
    sandxtom - 回复
50条评论
Still can't figure out the microphone manufacturer?
robertd1129 - 回复
Microphones are Knowles :: SiSonic™ Microphones http://www.knowles.com/eng/Products/SiSo...
Markus Ulsass - 回复
Can we know which model exactly ? or at-least its near specifications ?
kaushik wavhal -
Most likely SPA1687LR5H-1 since it is connected to the ADCs differential inputs and meets the specs and the dimensions.
Johannes
Johannes H -
does this have the same audio amp as the Echo (TI TPA3110D2)
Peter Cooney - 回复
I am trying to figure out why they did not use mems microphones with digital output and used analog ones with 4x ADCs . Wouldn't that have reduced BOM significantly ??
vinayshiv - 回复
Looks like those ADCs are more like mini DSPs. Probably has some AGC and some FIR filtering happening in there ...
vinayshiv -
Maybe the TI DSP chip has no or few PDM interface for the MEMs microphones.
williamc1014 -
Wish it had bluetooth microphone abilities.
Carlis Burns - 回复
How would you rate its moisture-resistance? Could it survive being in the bathroom during a hot shower?
Evan Jacobs - 回复
Has anyone done any serious software/hardware hacks to improve on its performance or add extra features?
John - 回复
Hi John
Theres a google hack....... email me brad1taylor@yahoo.co.uk
brad1taylor -
Has anyone torn down the new Echo Dot yet? Keen to see if they've upgraded anything of the innards.
Andrew Lin - 回复
I am currently Tearing down the Generation 2. I already got it opened up but wont be able to fully dissect it until next week. I can tell you already there is defiantly some notable differences but over all its very similar.
Aaron -
Thanks Aaron! Look forward to it.
Andrew Lin -
Yes i have just put photo's on my facebook. You should be able to see them. https://scontent-lga3-1.xx.fbcdn.net/v/t... https://scontent-lga3-1.xx.fbcdn.net/v/t...
timmerring -
+2. Did they upgrade anything from Generation 1 to Generation 2? Or is it minor changes?
Michael - 回复
Did Amazon upgrade anything from echo dot 1 to dot2 with anything new that causes any issues with disassembly?
Sam - 回复
Does anyone know exactly what type of plastic makes up the sides and the top piece?
Lauren - 回复
Has anyone noticed how where (or if) an input signal could be injected instead of microphone. Perversely, I am trying to use Alexa without a mic, and generate the voice commands from a disabled person's AAC device, rather than have to get Dot's mike to listen to AAC"s speaker. Cut out the middleman, so to speak (whoops, no pun intended!)Thanks for looking. Happy New Year, Stig.
Steve - 回复
The ADC has a digital input, you should look if it matches your output and then solder to it. Alternatively you could use the waveform coming from the output of your friend, use an opamp to create differential signals and the feed it to the same inputs like the micropohes are connected to. Be careful with the cable length though, could create a lot of noise.
Johannes H -
On the DM3725 Media Processor is about $45 a chip and $26 in volume. Amazon could have used a BCM2837 quad processor which has a base price of $8.00 ea. Not sure how their making money selling this unit at $50 and making any profit margin. I just purchased the Echo Dot and instead of having the volume wheel they went to a plus and minus button for volume control. So now their are 4 buttons on the top of the unit.
Kent Harris - 回复
It's possible that they're not making money on these. The quantity of data Amazon can collect from people using Alexa may make it worth only breaking even on this hardware.
Evan Noronha -
In addition, it isn't unlikely that Amazon and TI have a Business-to-Business agreement allowing Amazon to get TI hardware for a unique price. TI will benefit from Amazon using this chip, because a high-profile company such as Amazon putting trust in this chip will inspire other companies to trust this chip. This will likely help TI in both sales and stock prices. Therefor, selling this chip in a MASSIVE quantity to Amazon for a lower price isn't as scary of a prospect for TI. I also agree with Evan, although I imagine they will break even at the very least on this product.
Scott Havard -
There is no way Amazon is paying $26 for the processor. The DM3725 is a single core Cortex-A8 device with a TI DSP, in a thoroughly mature 45 nm process (probably outsourced to TSMC, to boot), and I'm willing to bet the die size is still smaller than that of the 40 nm BCM2837 with its quad Cortex-A53 CPU complex, GPU, etc.
You can be certain that TI and Amazon have a direct purchase agreement as Amazon is a heavy user of TI mixed signal and power devices in their other products. Heck, anyone selling semiconductors to Amazon is doing so directly, without the need for a distributor (unless Amazon's assembly house uses a distributor for inventory management).
I'm sure TI is doing just fine selling to Amazon, although I suspect the BOM cost for the Dot is still probably such that Amazon is just covering costs with some margin built-in for resellers like Target, Best Buy, etc.
Austin Engineer -
Without knowing exactly how many of these devices are coming off the production line, there is no way anyone can work out the component, or final BOM cost however the silicon is going to be significantly cheaper than the prices quoted above, moreso if there is a revolving contract in place with the supplier. The Dot gen 2 already confirms departure from rotary to push button for the controls, meaning it is no longer Echo's spare rib.
Additionally Amazon have utilised the Poundshop subconscious by pitching it (at least in the UK) at this price. You want a Dot, but to get the free shipping you have to buy something else in the store to qualify. By browsing for something else if only for a few minutes they will have seen what your search characteristics are, your credit detail/records from the checkout to see if it is regular or impulse buying and target accordingly.
I'm more interested in who has access to the voice data since it will remain on a large SSD to be dissected for every nuance, for all eternity.
Steve Phillimore - 回复
What is the film tape part in the case? And what does it do? As seen on the side case in step 9
timmerring - 回复
That's a ribbon cable that connects the upper assembly to the motherboard.
Evan Noronha -
I was talking about the one that is sitting in the case not connected to anything as seen in step 9
timmerring - 回复
It is connected to the motherboard as shown in the second photo in step 7.
Evan Noronha -
Does anyone know how the wording is placed on the rubber foot pad? Is that a texture break? Screen printing of some sort?
snyderm - 回复
Can anyone tell me which type of switch amazon echo uses to power up? is it a push button switch or something else?
Sunny Desai - 回复
Has anyone any schemas of this Echo Dot?
Aurel Plugaru - 回复
Hi, if still interested in this: I’ll generate a schematic out of the microphone/LED-PCB in the next weeks, because I want to make it smaller and add some sensors as well. Mail me to “kueder (at) gmx . ch”.
Simon -
Did anyone research regarding what signals is on the "D" connection pads near of power socket (Step 8, J2 connector)?
https://d3nevzfk7ii3be.cloudfront.net/ig...
Are these contact pads for these interfaces: UART Rx/Tx; Factory reset; SDMMC; VCC, etc.? Anybody knows?
Aurel Plugaru - 回复
https://i.imgur.com/EWCwaCg.png
This was correct for the amazon echo but I havent tried it on the dot, with the echo you could connect through UART and then grubhack to root it
Paul Watson -
echo dot 2.. is a downgrade in chips over echo dot 1...from wifi(Atheros QCA6234 to mediatek) , ic , processor ( 20 $ vs 7$), and the plastic is a lot cheaper..
on echo dot 1.. you feel it like metallic..and heavy
Mahdi Farhat - 回复
Hi, can anyone know what is the type or # number of the leds at the led ring?
Thanks
Aviv
Aviv Grinboim - 回复
Do you have this figured out yet? I’ve determined they are discrete RGB common cathode type parts, but have not nailed down the exact maker yet. I intend to wire them out to remote LEDs.
Byron Reynolds -
where do you tap into the circuit board to bring a signal out to an external DAC?
Dan Kenton - 回复
Can you tell for sure if the microphone mute switch actually works? My girlfriend is paranoid that it’s still listening to what we say even when supposedly muted.
Gary - 回复
Does anybody know manufacturer of speakers?
Siva - 回复
What kind of connector does it have? It doesn’t look like USB-C, which seems surprising, given that that everyone seems to want it to “take off”.
jimwitte - 回复
USB-C is for computers, phones and external accessories alike. This device only uses USB for power, so a C port would be too big and more costly to implement than a normal USB micro B port.
Owen Davies -
Thank you for your excellent comments and the humor that goes along with it!
FiOS-Dave - 回复
What does the WiFi antenna look like? at 2.4 / 5 ghz it would seem to require a very shore one?
David Emond - 回复
has anyone been able to test what the voltage is of the LED lights?
Joel Johnston - 回复
my daughter tried the wrong headphone jack in our echo dot and a piece broke off in the hole where a jack could go. Any recommendations on how to get that out? it’s super lodged in there …..
jltjoelker - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 55
过去 30 天: 229
总计 124,412
