跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Alesis Palmtrack V3.1 Teardown, Alesis Palmtrack V3.1 Teardown: 步骤 1 中的图像 1,1
    • Open the back battery cover
  2. Alesis Palmtrack V3.1 Teardown: 步骤 2 中的图像 1,1
    • Unscrew the four back screws
  3. Alesis Palmtrack V3.1 Teardown: 步骤 3 中的图像 1,2 Alesis Palmtrack V3.1 Teardown: 步骤 3 中的图像 2,2
    • Remove the backing and the wire mesh microphone casing.
    • NOTE: The Speaker is connected to the motherboard and adhered to the back cover, so take caution when opening. I cannot foretell the chaos created if you break the speaker wire.
  4. Alesis Palmtrack V3.1 Teardown: 步骤 4 中的图像 1,1
    • Gently pull apart main plate from front cover.
    • Also note that there is a ribbon cable connecting the front circuit board to the motherboard
  5. Alesis Palmtrack V3.1 Teardown: 步骤 5 中的图像 1,1
    • Disconnect the ribbon cable.
  6. Alesis Palmtrack V3.1 Teardown: 步骤 6 中的图像 1,1
    • Feed the ribbon cable through this opening. This is much easier than disconnecting from the front circuit board, which requires delicate, if not impossible maneuvers to reconnect upon reassembly.
Lorca Strand
于04/02/14注册
11 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 281
