跳转到主内容
这个拆解是不是维修指南。 要维修你的的Airvape Legacy Pro,请使用我们的维修手册
  1. Airvape Legacy Pro Teardown, Airvape Legacy Pro Teardown: 步骤 1 中的图像 1,1
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Teardown, Angled look at PCB: 步骤 2 中的图像 1,1
    • Just another photo
  3. Airvape Legacy Pro Teardown, Under wireless charger: 步骤 3 中的图像 1,1
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
ShellingRook27
于08/21/19注册
1,876 声望
创作了7篇指南
团队
Repair For You Repair For You 的会员
Business
1 名成员
创作了11篇指南
4条评论
Looking forward to seeing this continue!
andypapster - 回复
nothing more with the teardown?
seedy53 - 回复
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 97
总计 653
