跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Afterglow Prismatic Wired Controller for Xbox One,请使用我们的维修手册
  1. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: 步骤 1 中的图像 1,2 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove clear casing: 步骤 1 中的图像 2,2
    • Use a Phillips #0 Screwdriver to remove the seven Phillips head screws.
    • Separate two halves of clear casing by holding one side and lifting the other.
  2. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 步骤 2 中的图像 1,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 步骤 2 中的图像 2,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove main circuit board: 步骤 2 中的图像 3,3
    • Lift motors off of controller.
    • Lift circuit board off of controller.
  3. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 步骤 3 中的图像 1,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 步骤 3 中的图像 2,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove secondary circuit board: 步骤 3 中的图像 3,3
    • Use a Phillips #0 Screwdriver to remove the three screws.
    • Remove triggers by lifting them off the circuit board.
    • Lift the circuit board off of the controller.
  4. Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 步骤 4 中的图像 1,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 步骤 4 中的图像 2,3 Afterglow Prismatic Wired Controller for Xbox One Teardown, Remove power and mute buttons: 步骤 4 中的图像 3,3
    • Remove the power and mute button by pulling them out. They will be loose at this point and may fall out by themselves.
Zachary Crandall
于01/14/14注册
151 声望
撰写一个指南
团队
Cal Poly, Team 17-5, Forte Winter 2014 Cal Poly, Team 17-5, Forte Winter 2014 的会员
CPSU-FORTE-W14S17G5
5 名成员
创作了6篇指南
6条评论
how u clean it because i accident spill tea inside i cleaned it once it worked for a weak and it started to do it again how can i fix it please help me
Xavier Adams - 回复
You should use an earbud/”q-tip” dampened with isopropyl alcohol (otherwise known as IPA) to clean all areas affected by the spill.
infiniti25 -
a phillips #0 doesnt seem to fit into the screws.
reagen_lionel - 回复
How are the poitve and negative leads soldered to the board as I would like to swap wireless internals into controller and keep the lights
glohoodlum - 回复
I am curious about the pair of programmable wheels on the underside, do they have any markings or part numbers on them that would help in sourcing replacements? I’ve been in touch with PDP and confirmed that my controller is past their warranty period, but it is only the underside wheels that have failed and I’m trying to find replacements.
S.R. Cooper - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 96
总计 26,507
