简介
This teardown is a working Actiontec Q1000 Modem, sold by Qwest as a Qwest Q1000.
你所需要的
The Qwest Q1000 modem, made by Actiontec.
Port side with antennas detached.
DSL and Phone in ports
4 Ethernet ports
USB port, reset button, and power jack
Not a screw in sight.
Testing out the light pipe with an LED throwie...
The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
Here are all the LEDS:
8 of the LEDS that work with the light pipe
One more surface mount LED
A white LED for illuminating the Qwest logo
A dual-color (red/green) LED for the WPS status indicator.
Repairability score: 8/10
The entire device is held together with only 4 screws.
The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
The antennas are replaceable as well.
The heat sink is soldered in place, making removal difficult.
The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
附加文件
3条评论
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - 回复
Hello. I have one of these that I want to switch the antenna for. Are you able to tell me which of the antenna wires is the positive and neutral (I realize the antenna itself doesn’t have positive & neutral, but I don’t know the relevant term). Both wires are grey and hooked together so it’s not easy to tell
earthscope - 回复
