跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的AWEI BT Earbuds,请使用我们的维修手册
  1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: 步骤 1 中的图像 1,2 AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: 步骤 1 中的图像 2,2
    • Remove Earbud Cushion
  2. AWEI BT Earbuds & Receiver Teardown, Secure Earbud for Separation: 步骤 2 中的图像 1,1
    • Secure Earbud End (eg:Vice)
  3. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: 步骤 3 中的图像 1,2 AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: 步骤 3 中的图像 2,2
    • Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
  4. AWEI BT Earbuds & Receiver Teardown, Inspect Separated Earbud Internal Wiring: 步骤 4 中的图像 1,1
    • Inspect Earbud Wiring
  5. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 步骤 5 中的图像 1,3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 步骤 5 中的图像 2,3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: 步骤 5 中的图像 3,3
    • Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
  6. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 步骤 6 中的图像 1,3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 步骤 6 中的图像 2,3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: 步骤 6 中的图像 3,3
    • Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
    • Assemble Unit in reverse order.
fugitiveALiEN
于02/28/13注册
188 声望
撰写一个指南
团队
My Techno Guy My Techno Guy 的会员
Business
1 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 32
总计 1,601
