简介
Its pretty expensive device to mix\stream audio and as a result it is 0 information how to get inside. So I take all my brave an do it own risk as a first explorer.
你所需要的
Remove rubbers (red). They are pretty dense so to not worry to damage them. Do not remove label (blue) - it have hole under, but it is not a screw hole
Remove 6 PH1 screws. Need to notice, that upper 3 screws are deep - so you need long thin screwdriver.
Unclick latches using long side of credit card. I recomend this because latches are really strong and not flexible, so this wat to do this will help to keep them alive
You need to do this above rgb line
Do both sides and bottom, after that upper side will free itself.
Do not pull upper half of streamer as it connected to bottom with wires
Lift bottom side and make colorful wire visible and acceseble
Unplug it. This part do not have any clips, so gust push it down
Flip bottom half of streamer more and make display and touchscreen plumes visible
Remove black isolation (if you have it) on bottom pcb
Lift black lockers
Remove plumes
Remove 6 PH1 screws on top
Im done on this, because my goal was to check any marks on screen. I think to fully remove top pcb you need to remove bottom parts of audio spinnerы but i cannot do it
