跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Computer Game Controller,请使用我们的维修手册
  1. ALPS RKJXV1224 Variants Teardown, Same part number, but different?: 步骤 1 中的图像 1,3 ALPS RKJXV1224 Variants Teardown, Same part number, but different?: 步骤 1 中的图像 2,3 ALPS RKJXV1224 Variants Teardown, Same part number, but different?: 步骤 1 中的图像 3,3
    • Both of these switches are ALPS RKJXV1224 and are common in most gaming controllers from PlayStation 3 through 5, Xbox One through Series X|S, Switch pro controllers, and most third party joysticks.
    • However, it appears that over the years Alps has made some changes. On the left, with white Pots is an earlier revision 002 pulled from an earlier Xbox One controller without bluetooth.
    • This third photo shows revision 005 with the black Pots (potentiometers) pulled from an Xbox One wireless controller.
    • It is also apparent that Alps has changed the spring setup for this variant, but I have found either.
  2. ALPS RKJXV1224 Variants Teardown, Left/Right cage on a diet: 步骤 2 中的图像 1,1
    • The Left/right cages of the joystick have been revised. Likely to reduce cost.
    • On the left is the cage from the older revision 002 that averages .7mm in thickness and has .8mm thick arms. These were changed from copper in the Xbox 360 to plastic for newer controllers.
    • On the right is the cage from the new revision 005 that averages only .5mm in thickness and has .6mm thick arms. It is very easy to bend, and could allow the pot to be twisted without moving the stick.
  3. ALPS RKJXV1224 Variants Teardown, Potentiometer woes: 步骤 3 中的图像 1,2 ALPS RKJXV1224 Variants Teardown, Potentiometer woes: 步骤 3 中的图像 2,2
    • First we have the older style potentiometer that appears to be more robust than the new revision. It has three wipers and a back plate that appears to seal up better. The wipers also look to be plated which may reduce wear.
    • The newer style pots only have two wipers that are bare copper. The back plate is smaller and has a couple gaps which may let in more dust.
  4. ALPS RKJXV1224 Variants Teardown, loosen up your belt: 步骤 4 中的图像 1,2 ALPS RKJXV1224 Variants Teardown, loosen up your belt: 步骤 4 中的图像 2,2
    • Last we have the bodies. These are both stamped out of the same thickness material, but the older revisions appear to have slightly more metal near all corners allowing tighter gaps. This may allow more dust and debris to get into the newer revision switches.
    • While still available in the aftermarket, older revisions of these joysticks may not be available for long. It appears that cost saving measures have introduced problems for gamers.
Nicholas Brown
于11/24/17注册
142 声望
撰写一个指南
一条评论
Witch switches are correct one for Xbox One / One S Controller? (I have both controller versions) RKJXV122400R should be OK?
If the previous question is not to hard, then witch switches are used for wired xbox 360 Controller? (I have also this one - maybe I could also fix it)
Tomasz - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 38
过去 30 天: 187
总计 4,965
