跳转到主内容
« 返回到所有故事
Replaced failing hard drive on 21.5" iMac
eshienbrood -
我的问题
The existing 500GB internal drive on my late 2009 21.5" iMac was developing an increasing number of bad sectors, and was probably close to failing.
我的修理方法
It was quite easy, and took less than an hour, with the proper tools.
我的建议
Use a tweezers or small pliers to help extract and insert the Torx screws that attach the display to the case. Otherwise, you risk dropping the screws into the case, which means you'll have to remove all the screws and lift the display in order to retrieve them.
Spudger图片
Spudger
$3.99
Metal Spudger Set图片
Metal Spudger Set
$7.99
Heavy-Duty Suction Cups (Pair)图片
$14.95
« 返回到所有故事
0条评论
添加评论
