我的问题
Battery was growing and lifting the screen off the keyboard when closed.
我的修理方法
First off.... It was not a NEGATIVE experience.... but I damaged my MAC in the process and I feel there could be some additions to the guide.
2016年末带 Touch Bar 的15寸 MacBook Pro 电池更换
Step 40:
I pulled the left speaker connector ( the smaller of the two) off the PCB trying to " TWIST AND PRY" the cable off it.
I think you need either add a fourth image to show it pulling STRAIGHT UP or add a separate step just for that smaller left speaker connector.
Also, I would delete the word TWIST and add a disclaimer to be gentle with that one.
http://www.imageshift.com/misc/macbook_s...
Step 49:
I left ONE ribbon cable tucked under the logic board when reinstalling. Not cool..ha.
I would give the user a total number of cables to account for when reinstalling...perhaps with them all listed by name or images, before continuing with the assembly.
Step 63:
I think I cracked my screen pushing down too hard to scrape off the old adhesive tape. The screen is fine and still looks great.... but now there's a crack horizontally through the middle. I believe its where the edge of the "absorbent towel" I used was.
I did not catch the fact the guide was referring to the super-thin paper towel that was included. I thought it just meant an "absorbent towel" so I put a washcloth under there. It was too thick I believe.
I would change the text to read... "Optionally, you may also lay the included absorbent paper towel directly underneath..."
...yes...I realize there was a link NOW... but it was not OBVIOUS when I was in knee-deep into the repair. :)
- I would also consider having the user open the laptop over the edge of a table to have the screen hang off the edge so that they're not pushing down on it as they try to scape the adhesive strips off the case.
我的建议
see " the Repair" section for advice for this repair..........
0条评论
