我的问题
It wasn't charging, the iPad would see the charger was plugged in, but no charge would go to the battery.
我的修理方法
It went well, i used the iFixit repair guide to make sure i was doing it correctly. Only issue i had was that i broke the home button cable and had to replace that as well, I didn't pull the pick out quite far enough on the side with the cable, but that was easy to fix as well.
我的建议
Be careful on the left side, i thought i had the pick far enough out but i still managed to snag the home button cable. Its always a bummer when you have to fix more parts than you needed to.
0条评论
