跳转到主内容
修复你的物品
维修的权力
商店
« 返回到所有故事
Not simple, but doable!
Pete H -
iPhone 5s
iPhone 5s LCD and Digitizer Replacement
3小时
Moderate
我的问题
The screen was SHATTERED!
我的修理方法
Only a few snags. Getting the iSight camera aligned when re-assembling can be a little challenging.
我的建议
When you need heat - I use a hair-dryer on low fan, high heat for about 30 seconds and it worked superbly.
When you need to re-install the iSight Camera, get everything as close to where it belongs as you can. Get the bracket aligned, and then tighten the screws. Check the camera lens for alignment with a bright flashlight. If it's not aligned, loosen the screws and use a spudger to get the lens where you want it. re-tighten and check again. Do this BEFORE you put the entire phone back together!
Patience.
« 返回到所有故事
0条评论
添加评论
