我的问题
The SuperDrive would not accept a disk.
我的修理方法
The repair went very smoothly.
我的建议
Step 10 of the repair guide suggests you remove the ribbon cable attaching the SuperDrive connector to the logic board. I found this to be unnecessary. After removing the three screws holding the drive in place, I was able to lift the drive gently and slide it off the connector. Slipping the new one on the connector was just as easy. I try to avoid separating ribbon cables if I can avoid it.
0条评论
