跳转到主内容
« 返回到所有故事
iMac 2009 power Supply & HDD replacement
michaelderickson -
我的问题
Multiple problems, including a corrupted hard drive and blown capacitors on the power supply, likely due to lightning strikes.
我的修理方法
Great following the iFixit guides, including the power supply instructions. The help for reattaching the monitor cable by undoing the power supply, connecting the monitor, THEN re-attaching the power supply made things orders of magnitudes easer. Booted up first time after the PS & HDD replacement like a charm. Had to install Yosemite via USB drive.
I had previously bought several of your tools including the glass suction cups, the torx socket set and spudgers, so repairs were a breeze having the right tools for the job!
我的建议
Add in instructions/pictures for how to tell if the power supply is bad. In my case, 3 of the capacitors were not leaking but were simply bulging, from what i was reading on the internet that means they have failed and no longer supplying power properly. Booting without the cover confirmed this as the 4leds in the lower right corner, lit up #1, boot-up chime, 2-4 lit in sequence, screen flickered, then all went dark, including #1 led. So at that point I knew the PS was toast.
iMac Intel 24" EMC 2267 2.66, 2.93 & 3.06 GHz Power Supply图片
$139.99
« 返回到所有故事
0条评论
添加评论
