iMac Opening Wheel
  • iMac Opening Wheel / Complete Tool / New  / Individual
  • iMac Opening Wheel / Replacement Wheels / New  / 5
  • 360°
360
iMac Opening Wheel
US$7.99
US$7.99
当产品有货时,我们将给你发送消息。
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
产品详细说明
描述
描述
It's like opening an iMac pizza
  • The unique design of recent iMac models requires the cutting of the foam tape on the display to get inside.
  • This tool comes in two parts:
    • The handle is made of reinforced nylon and easily accommodates the cutting wheel while providing plenty of grip. In addition, the back of the handle features a thin prying and slicing blade to ensure you loosen all the adhesive.
    • The cutting wheel is specifically designed to slip in the hair-thin gap between the display and the aluminum frame, then easily cut the foam holding the two pieces together.
兼容性
iMac 27" 2017
EMC 3070 3.4 GHz
EMC 3070 3.5 GHz
EMC 3070 3.8 GHz
EMC 3070 4.2 GHz
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Late 2015)
2.8 GHz (Late 2015)
iMac Intel 21.5" EMC 3068
EMC 3068 non 4K 2.3 GHz
iMac Intel 21.5" Retina 4K Display (2015)
EMC 2833 3.1 GHz
EMC 2833 3.3 GHz
iMac Intel 21.5" Retina 4K Display (2017)
EMC 3069 3.0 GHz
EMC 3069 3.4 GHz
EMC 3069 3.6 GHz
iMac Intel 27" EMC 2546
2.9 GHz (Late 2012)
3.2 GHz (Late 2012)
3.4 GHz (Late 2012)
iMac Intel 27" EMC 2639
3.2 GHz (Late 2013)
3.4 GHz (Late 2013)
3.5 GHz (Late 2013)
iMac Intel 27" Retina 5k Display
EMC 2806 3.3 GHz (Mid 2015)
EMC 2806 3.5 GHz (Late 2014)
EMC 2806 4.0 GHz (Late 2014)
EMC 2834 3.2 GHz (Late 2015)
EMC 2834 3.3 GHz (Late 2015)
EMC 2834 4.0 GHz (Late 2015)
iMac Pro
EMC 3144 2.3 GHz (Late 2017)
EMC 3144 2.5 GHz (Late 2017)
EMC 3144 3.0 GHz (Late 2017)
EMC 3144 3.2 GHz (Late 2017)
显示 10 个更多的设备
维修的故事
用户头像
Mikel Neal's Story Photo #1419075
Mikel Neal's Story Photo #1419079
Mikel Neal's Story Photo #1419077
我的问题
Failed hard drive. Replaced with SSD.
我的修理方法
Fairly tedious. Made sure to clean any leftover adhesive from original adhesive strips with rubbing alcohol. Took my time and got the display perfectly centered.
我的建议
BUY THE CUTTING TOOL FROM IFIXIT. It also helps to have a spudger to remove the original adhesive st . . .
用户头像
markford's Story Photo #906768
markford's Story Photo #906767
我的问题
Stock hard drive too small (1Tb) and decided to install a Seagate 4Tb Fusion drive.
我的修理方法
Perfect.
我的建议
Key Tips - 1. Read both the Hard Drive, Display and Adhesive Strips guides, including user comments before picking up a tool, 2. Have the correct tools, hard drive and adhesive strip kit, 3. Have patience
用户头像
我的问题
Changing hard drive to SSD
我的修理方法
Great, The iMac Opening Wheel tool made the job so easy to get done.
我的建议
Be Patient
用户头像
我的问题
The computer had worked very slow for months so I ended up redeploying it in a hobby room. After a month it failed to boot, and recovery mode wouldn't work and First Aid failed.
我的修理方法
The replacement of the HDD and the application of the adhesive strips went EXACTLY as described (including the slip of the . . .
用户头像
我的问题
Installed 16GB of Ram and 512GB SSD
我的修理方法
It went great, definitely take your time and keep track of where screws go
我的建议
As I removed screws and did the steps, I kept the parts in zip lock bags together, which made putting it back together that much easier!
用户头像
我的问题
Had to remove and replace Hard drive
我的修理方法
Went well, took about 2 hours.
我的建议
Take your time, do not rush it. When lifting the Screen to remove connections, it was helpful to have an assistant. He held the screen up, while I unplugged those pesky connectors. Also, when removing the old adhesive strips, you can . . .
用户头像
我的问题
Apple STUMPED - iMac shuts off randomly, daily to multiple times/hour
我的修理方法
Repair went perfectly. Time will tell if the power supply was truly the culprit in the issues I was having that Apple was UNABLE to diagnose.
我的建议
You might have to run a card or spudger a few . . .
用户头像
我的问题
Slow hard drive swapped with SSD.
我的修理方法
Touch and go for a moment cutting off the glue from the screen.
我的建议
Once you are able to pry the screen apart, you are able to get to everything and re-tape back the screen
be patient and steady hands to tape back the screen and make sure you have finger nails
用户头像
我的问题
The old HDD was really bogging down the iMac, the SSD gave it new life.
我的修理方法
Surprisingly easy. The iFixit iMac opening tool made the repair a cinch.
我的建议
Have a second person that can help.
用户头像
我的问题
I love the iMac hardware more than any other all in one that I've ever tried but the HD was sooo slow!
我的修理方法
After watching the video a coupled of times, the tools were perfect for the job and I was able to manage swapping out the hard drive in less than 40 minutes.
我的建议
Watch the video until you have the confid . . .
显示更多
