Xbox 360 Opening Tool
  • Xbox 360 Opening Tool
US$4.99
US$4.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Used to open the plastic outer casing of the Xbox 360.
维修的故事
我的问题
Tray replacement
我的修理方法
The xbox opener tool is the end all be all when it comes to opening these things. opened quite a few of them, and it is a coin toss as to whether or not the case will disintigrate, or bite you back. the opener removes all doubt. seperated the back plates as smooth as butter.
我的建议
use the t . . .
我的问题
Well this one specifically helped with repairing a bricked, 360. However the real purpose was putting together a toolbox.
我的修理方法
Went great, resurrected an '07 360 (Dead DVD), and it finally was able to see firmware beyond the Blade style dashboard.
我的建议
Nothing on my end, keep up the great site.
我的问题
The DVD tray was stuck open after the XBox 360 was dropped.
我的修理方法
I was able to remove the DVD and place the tray back successfully. The dvd games cannot be read and played and I need to take the DVD out to see if I need to replace the laser unit.
Are there any instructions available on how to use the . . .
我的问题
After a big lightning storm, I could not sync my wireless controllers and the ring lights would not come on. RF Board fried.
我的修理方法
The tools made getting to the fried RF Board really easy.
我的建议
While I was at it I ended up replacing the green lights with blue ones. I had bought a cheap RF Board with blue lights . . .
我的问题
Wireless controllers would not sync with Xbox 360 and the power light would not come on.
我的修理方法
The repair went well except for the Spudger tip broke almost immediately- very disappointed with that. IFixit guide was extremely helpful and assisted me in successfully installing a new RF Module board on my 3 . . .
我的问题
Xbox disk read error.
我的修理方法
Easy
我的建议
Make sure you open the xbox first so you get the right drive.
我的问题
A friend gave me a RROD'd original Xbox 360.
我的修理方法
I read several guides and decided to use the 8-penny method (Pushing up the mobo at the RAM with make-shift stints) and then turned it back on and let it run with air-flow blocked to the GPU for ten minutes. After a couple hours, to let it cool, I turned . . .
我的问题
My friend's Xbox 360 Elite recently got the dreaded "Can't open tray" error. Unfortunately, he tried to manually remove the disk (incorrectly, but what can I say?), and the tray both came off-track AND managed to damage the tray motor. It was very clear that the drive was toast. He called me, asking . . .
我的问题
I fix my Xbox 360 in order to save money if I can and I didn't want to recycle it unless there was a way to fix it.
我的修理方法
It was little difficult to fix the problem but it help me get the Xbox 360 working again.
我的建议
Just relax while repairing your console and take one step at a time and don't rush it.
我的问题
cause it was already open pass warranty
我的修理方法
great it worked
我的建议
nope, worked good
显示更多
