Tri-point Y0 Screwdriver
  • Tri-point Y0 Screwdriver / iFixit - Made in Germany / Fixed Blade
  • Tri-point Y0 Screwdriver / Moody - Made in USA / Fixed Blade
US$8.99
US$8.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Use this precision Tri-point Y0 DIY or professional electronics repair. Slightly different from a "tri-wing", this driver fits some of the smaller "tri" screws found on Apple track pads and other products.
The iFixit Tri-point Y0 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Tri-point Y0 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
维修的故事
我的问题
The battery was almost 9 years old and only had 57% charge capacity left.
我的修理方法
The repair was very simple. I believe it took longer to restart the laptop then to do the replacement.
我的建议
Make sure to read, understand and follow the directions in the guide.
我的问题
2 problems: First, battery losing life, then computer could not communicate with hard drive.
我的修理方法
Went well. The drive cable was a bit of a challenge because of the need to bend it at sharp right angles to fit stair-step in upper case where it gets fastened with screws, but after several tries, got it to . . .
我的问题
Battery was completely dead
我的修理方法
Super easy and very helpful guide to understand and follow
我的建议
You guys do great work thanks!
我的问题
Original battery was swollen
我的修理方法
Nice and simple
我的建议
Be sure to read the guide. There was one connector I originally overlooked that the guide pointed out.
Have the right tools. The screws that hold the battery in place would be badly damaged and likely the screwdriver I used would be too.
我的问题
Electrical part which had a relative simple problem to fix.
我的修理方法
Very well - as expected.
我的建议
When unsuccessful finding the appropriate tool at the local hardware store, go to the internet - especially the iFixit website.
我的问题
No problem, only self install 0,35$/GB common ssd Instead of 3 times the price of Apple's ssd...
我的修理方法
Good. ifixit video tutorial + adhesive parts make it easy
我的建议
Carefully remove the bottom Edge adhesive. Don't use a cutter to cut it , Risk of scratching the back of the bottom glass panel edge , (visible on . . .
我的问题
Only my grandson knows
我的修理方法
Hasn't started yet-- gets parts Dec. 25
我的建议
Ask for recipients email
我的问题
Screen was broken and I decided to fix it instead of replacing the whole unit.
我的修理方法
We followed the instructions step by step and it went very well. The phillips screwdriver ended up not really working on the first set of screws but i had another that was better but other than that everything went really . . .
我的问题
have used ifixit site before and was very pleased with outcome
我的修理方法
the repair went smoothly; my trackpad repair came without the cable so i needed to swap that over so there should be a couple of pics on how to do that
我的建议
don't be afraid to tackle such a project; plenty of guides and tools available to do th . . .
我的问题
My trackpad had become extremely hard to click and took a lot of force to do any clicking. So, I decided to replace the pad and upgrade the RAM while I was inside the computer.
我的修理方法
The repair was simple and easy and took about 25 minutes to complete. I even did a lot of cleaning inside the computer while . . .
显示更多
