产品详细说明
描述
If you find yourself out and about and in need of a fix, this kit will have you covered. Measuring a portable .9" x 1.8" x 4.9", repair a lot with a little pocket-sized Minnow Driver Kit.
We built the Minnow using data from thousands of repair manuals and teardowns, ensuring you have the most compact assortment of bits for electronics repair. Our 4 mm precision bit driver handle has an integrated SIM Eject pin, magnetic bit socket, knurled grip, and swivel top—and each of the 16 precision bits has a 4 mm hex shank and extended-reach long neck.
Standard bits like Phillips and Flatheads will get you into most small household appliances and electronic devices, while security and exotic bits like Pentalobes will gain you access into Apple devices like iPhones and MacBooks. Whether you're a professional fixer or a weekend warrior, accidents happen everywhere. The Minnow has what you need to disassemble and repair smartphones, laptops, wearables, drones, pocket knives, and more—on the go or at home.
套装内容
- Easy-to-Open Magnetized Case
- Lid with Built-in Sorting Tray
- 4 mm Precision Bit Driver with Integrated SIM Eject Tool
- 16 Screwdriver Bits
- Phillips - 000, 0, 1
- Flathead - 1, 2.5 mm
- Torx - T3, T4, T5
- Torx Security - TR6, TR8, TR10
- Pentalobe - P2, P5
- Tri-point - Y000, Y0
- iPhone Standoff Bit
产品规格
客户评价
