Metal Spudger
  • Metal Spudger
Metal Spudger
$2.99
$2.99
当产品有货时,我们将给你发送消息。
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
产品详细说明
描述
描述
For when you need that unyielding edge.
  • While our first-choice tool for poking and prying is always our trusty plastic spudger, sometimes you need a little more power behind your pry. In those instances, this metal spudger is the ideal tool for the job.
  • Features a comfortable, easy-grip handle and is great for prying up all sorts of tough components.
  • For the metal spudger fanatic, we also sell a set with an entire assortment of four different metal spudgers, for all of your hardcore spudgering needs.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
产品视频
维修的故事
用户头像
Gordon Krupsky's Story Photo #863027
我的问题
About a year ago, my left channel went almost dead. It was there, but so faint that you couldn't really hear it. I don't listen to my iPod through headphones too much, but I do use an FM transmitter in my car that gets audio via the headphone jack. In the car, instead of just having a dead left chan . . .
用户头像
我的问题
Battery would not charge.
我的修理方法
Difficult to open the case, but was able to do it with patience, and without damaging the case.
我的建议
Study the pictures in steps 21 and 23 to understand what the clips look like and the locations so that you know where and how to probe with the metal spudger to release the clips.
用户头像
我的问题
Battery
我的修理方法
Awesome
我的建议
Do not use them rip off kiosks at the mall. Do it yourself! It's very easy and way cheaper.
用户头像
我的问题
Crack screen on a Verizon Surface 3, unusable in it's current state.
我的修理方法
Getting the old screen off was a pain. Lots of little pieces. Wish i would have known to just get one corner done and get to the meat of the screen. From there i could have possibly pulled it off faster with less shards!
我的建议
Rated as a 1 . . .
用户头像
我的问题
Won't boot up
我的修理方法
Order arrived in reasonable time & good condition. Prybars popped the case of Nexus 7 quickly & undamaged as advertised. Didn't find the quick & easy loose battery connection hoped for but tools were great. Will continue & possibly use other tools as time allows.
我的建议
Best advice may be buy . . .
用户头像
我的问题
Recently, I needed to replace the battery on my 6-year old Dell Adamo 13. I referred to the clearly written Dell Adamo 13 Teardown and clicked on the "Buy these tools" button to order all the recommended tools.
After receiving the tools, I realized that I still had no way to open the computer case . . .
用户头像
我的问题
Front panel cassé!!
我的修理方法
Bien été mais il faut faire attention de pas trop chauffer avec le heat gun!! Regarder aussi le vidéo en plus des étapes!
我的建议
Suivre les étapes et prendre sont temps!!
用户头像
我的问题
broken display
我的修理方法
I bought the wrong display and I had no problem with the return. I got the right part and I followed the steps and had no problems. Thanks!
我的建议
Follow the steps very easy!
用户头像
我的问题
iPad was discharging quickly. Then it would not charge at all. Would not turn on or charge (dead). Determined the battery needed replaced.
我的修理方法
Used the iFixit guide and was able to successfully repair. I used a hair dryer to soften the adhesive and was very patient (heat, cautiously pry, heat and pry, . . .
用户头像
我的问题
Accidentally our iPod classic fell unto the floor and consequently the harddisc was broken. The best solution seemed to be a replacement of the drive with a CF-card. If there is any pride, you go for it on your own and fix it.
我的修理方法
To start the opening process I found it easier to use a kitchen knife ins . . .
显示更多
