Metal Spudger Set
  • Metal Spudger Set
  • Metal Spudger Set
Metal Spudger Set
US$7.99
US$7.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Four times the brawn.
  • Any fixer knows that moment when you're stuck needing that one tool for the job—be prepared for the moment before it hits, with our assortment of four sturdy metal spudgers.
  • Easy-grip handles of just the right length for comfort and leverage.
  • Just the right amount of spring to pop out components and pry up against sticky adhesive.
Kit Contents:
  • Classic Metal Spudger - the tried and true original
  • Single Flat - with an extra long blade, great for iPad batteries
  • Small Pointed - reinforced and thick on both ends, good for scraping
  • Classic Wide - wide and slightly curved with rounded and pointed ends
  • Fitted Pouch - flexible plastic tool roll to keep your spudgers at the ready
Be sure to exercise caution when using these tools. With their great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
维修的故事
我的问题
the right side headphone jack didn't work
我的修理方法
Difficult but i did replace it in about 2 hours
我的建议
just follow the instructions, they are great !
我的问题
Need to replace my existing battery pack. It got bulky and blocked my trackpad to function properly.
我的修理方法
The repair was great. Easy to follow instruction from ifixit was no hassle. Only took me 10-15 mins to fix my mac and works like a Pro.
我的建议
Everything was perfect.
我的问题
Simple screen replacement. I watch videos and look at teardowns to prepare for those little things smartphones are so full of. I replaced the screen because it was cracked (bought it that way). No display but the soft-keys did light up.
我的修理方法
The repair went fine. I had to salvage the frame. Tedious work . . .
我的问题
I'm hard on phones and iPads. I can't even wear a watch. It ends up scratched, dented or in pieces within 6 months.
我的修理方法
It's the second time for the iPad mini digitizer so it was much easier. First time for the phone and that was simple too.
我的建议
The one recommendation I have is read the step by step instruc . . .
我的问题
The WiFi on my wife's iPad 1 suddenly died. No Wifi signal and no access points showed at all. I researched the repair and found a possible solution on the iFixit website, so I decided to give it a try and order the WiFi/Charging port part. I also learned that the display clips frequently break w . . .
我的问题
iPad repair
我的修理方法
Got these just in time for my iPad repair. Made the job MUCH easier!
我的建议
Not a must have,but very close.
我的问题
Lack of anger mgt. Threw s5 at wall, wall won!
我的修理方法
Way faster than I expected.
我的建议
magnifying glasses and plenty of white light. Watch several videos there are several ways to skin a samsung, I used parts of all the ones I watched.
我的问题
I used the Jimmy and Metal Spudger Set to remove the Glass from a Samsung S3.
我的修理方法
unfortunately the Cracks in the glass where all the way through the LCD, the the tools worked great. The Jimmy as used almost exclusively.
我的建议
Humm, well if your glass is very shattered take your time to get all the center glas . . .
我的问题
Wanted to speed up my iMac performance. The RAM was already maxed, so the only thing left to do was upgrade the what's drive to an SSD.
我的修理方法
It was pretty smooth. Much easier than I thought it would be.
我的建议
I think it's worthwhile to upgrade the ram & SSD on your older Mac before going out and buying a new one . . .
我的问题
Friend needed new screen assembly replacement
我的修理方法
Followed the directions, warning stated " not for the faint of heart"!
So iread it over and over, it was dificult had a question ifixit answered within 15 minutes.
So pleased perfect results, so happy and productive and now i have some experience with one . . .
显示更多
