产品详细说明
描述
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added.
- Lead Free Solder. Coiled into convenient dispensing tube.
- Melting point of 446/230 degrees F/C.
Specifications:
- Material: 99.3% SN, 0.7% Cu, rosin core
- Weight: 0.5 oz / 14 g
- Diameter: .04" / 1 mm
- Melting Point: 446 ° F / 230 °C
客户评价
