Heavy-Duty Suction Cups (Pair)
  • Heavy-Duty Suction Cups (Pair)
  • 360°
360
US$14.99
US$14.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Large glass panels rarely come with handles. Use these suction cups to safely lift and remove glass and display assemblies from devices.
We specifically built these suction cups for iMac repair. For years we struggled with finding a reliable source for quality suction cups, so we bit the bullet and engineered our own. The specially formulated rubber foot sticks stronger and longer.
Includes two 2.25" diameter suction cups used for lifting display glass off Aluminum iMacs—or anything else that needs heavy duty lifting. A must-have for any iMac repair.
维修的故事
David Robledo's Story Photo #1303672
David Robledo's Story Photo #1303671
我的问题
I had the iMac 2011 grey screen, to blank screen, to crazy demonic rainbow screen.
我的修理方法
Ordered the Pro-Tech Toolkit a Magnetic Project Mat and the suction cups. Figured it would be cheaper to try to open and check for damaged cables or power assembly. I’ve never done anything THIS involved. Reluctantl . . .
Brent Lewis's Story Photo #1317153
我的问题
Hard drive in an iMac 21.5" was failing so needed to replace the hard drive for continued use of the machine.
我的修理方法
It was smooth for most part outside of a couple of annoyances (detailed in the "Enlightenment section). Had it not been for the lack of connector puller/long fingernails and magnets near the . . .
我的问题
My iMac’s screen showed yellow vertical stripes and the boot process would not complete.
我的修理方法
Spread over two days, the repair process was tedious, but thanks to the iFixIt guide and especially a few of the added comments on missing steps, transposed descriptions of connections, etc., it was ultimately . . .
我的问题
The backlight turned itself off every 5 seconds when the brightness was above level 3. (16 is full brightness). Needless to say I got fed by all the squinting I did at my screen just to see what was going on.
I sent my iMac to 2 different repair shops, but unfortunately without getting it fixed (a . . .
我的问题
Upgrade battery for better speed and performance.
我的修理方法
My son is 14 y.o. and has done many display replacements since he is careless and drops his phones often. This was his first battery upgrade and everything went well until he had to use the credit card trick to remove the battery and adhesive strips. . . .
我的问题
I could only charge wirelessly
我的修理方法
I missed 2 screws and shattered the digitizer
我的建议
Remove the seal and count the screws.
我的问题
We had a mid-2011 27" iMac that had never been used much.... sometimes bigger isn't always easier to use! Moving some furniture allowed us to consider using it again but it wouldn't start up, no lights, no sounds, just dead. Rather than recycling a barely used machine we decided to risk spending t . . .
我的问题
Original power supply was dead.
我的修理方法
About an hour.
我的建议
Wow, this replacement was awesome. I've been working with electronic equipment for 30 years and this was one of the smoothest replacements I've ever done. The part from Ifixit was beautifully packed and the part appeared to be OEM. Thankfully the Mac i . . .
我的问题
Original battery was not holding a charge.
我的修理方法
Excellent, downloaded a calibration APP to try to help the charging scenario.
我的建议
Ifix is awesome!
我的问题
I have two five year old thunderbolt displays, One with no video and one with broken glass. I determined that the one with no display had a bad built in cable by plugging a thunderbolt cable into port on the back. When I found the teardown guide, I looke like a straighforward procedure. To test the . . .
显示更多
