Heat Gun
  • Heat Gun
  • Heat Gun
Heat Gun
Heat guns may produce residual smoke when turned off the first few times and should always be used in a well-ventilated area.
US$19.99
US$19.99
当产品有货时,我们将给你发送消息。
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
产品详细说明
描述
描述
Great for reflowing solder and melting adhesive.
  • The power of fire in the palm of your hand (except for the part where flames actually come out).
  • 1500W Heat Gun needed for many different repair processes.
  • Can be used to loosen adhesive holding device components in place, or to reflow solder to repair soldered connections.
High and Low Heat settings
  • Low setting reaches 570/300 degrees F/C.
  • High setting reaches 1112/600 degrees F/C.
The high setting can ignite things. It can also burn you. So watch out!
For the professional heat gunslinger, check out our pro model, the Hakko HJ5000.
Available for shipment only to the USA due to voltage requirements.
维修的故事
用户头像
Phil's Story Photo #1672575
Phil's Story Photo #1672574
Phil's Story Photo #1672573
我的问题
Battery died and would no longer charge or hold a charge anymore. Phone could not turn on for more than a second before shutting off.
我的修理方法
Went well except I damaged my screen getting the battery out. It now has a spot of dead pixels and green lines running down the phone.
我的建议
Be careful when removing the old . . .
用户头像
Steven Rice's Story Photo #815542
Steven Rice's Story Photo #815544
我的问题
My friend dropped her phone in a parking lot.
我的修理方法
I do NOT like how this phone was constructed. I was actually maimed in the process of repairing this thing. It uses these tiny little pins to hold a metal frame onto the screen assembly. It is a horrible design. I ended up getting one of those stupid litt . . .
用户头像
我的问题
iPhone 8 plus screen was in very bad shape and in need of repair.
我的修理方法
Repair was as expected. Screws were small and care had to be taken not to mix them up. Make sure to have a hot air source available to loosen the glue.
我的建议
The home button removal from the old screen goes much easier if you heat it too. One . . .
用户头像
我的问题
3 year old dropped it and shattered the screen
我的修理方法
again- super easy, with the right tools. I tried with cheap picks and spudger that came with the replacement screen i got from ebay...big mistake. the picks broke with half inside and half outside the case. the cheap spudger bent and was worthless. w . . .
用户头像
我的问题
Charging was intermittent and battery runs out fast - now all good with the replacement parts.
我的修理方法
Doing both of these at the same time is a good idea. Good parts, good repair.
我的建议
I grabbed a BIG local business advertisement magnet from my fridge and used that up side down for all of the screws and parts. . . .
用户头像
我的问题
A customer's iPhone 6 was draining battery very quickly, from 55%, it would go down to 0 in around 10 minutes. I knew this was a battery problem.
我的修理方法
The screen and battery connector were very easy, but the biggest challenge has to be the iPhone 6 battery adhesive. It is so tough, and the pull tabs rip v . . .
用户头像
我的问题
My Galaxy Mega 2 had a shattered screen.
我的修理方法
The repair is pretty easy as long as you take your time removing the glass. It's just held together with tape so just heat it up a little around the edges and use a pick or another small tool and run it along the sides and off she comes.
我的建议
Take your time and he . . .
用户头像
我的问题
RROD
我的修理方法
Repair was easy enough, just followed the directions. May want to watch a video or 2 on the X clips, pretty easy to destroy the whole motherboard if you screw this part up.
我的建议
The whole process was pretty easy. To do the reflow, instead of initially heating the board with the heat gun, I put it in t . . .
用户头像
我的问题
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
我的修理方法
Repairs go a lot quicker with the right tools.
我的建议
Make sure you have the ri . . .
用户头像
我的问题
I fixed it because it ha front and back screen broken.
我的修理方法
The repair went great it's fixed.
我的建议
None i did it on my own.
显示更多
