Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver
  • Flathead 3/32" or 2.5 mm Screwdriver / iFixit - Made in Germany
  • Flathead 3/32" or 2.5 mm Screwdriver / Moody - Made in USA
US$6.99
US$6.99
当产品有货时,我们将给你发送消息。
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
产品详细说明
描述
描述
Use this precision flathead screwdriver for electronics repair and DIY projects. It's the most basic screwdriver you'll need in your toolkit to fix laptops, small home appliances, and electronics. The small, flat screwdriver blade is also known as the "slot", "common", or "standard" screwdriver.
The iFixit flathead screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision flathead screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
维修的故事
用户头像
我的问题
Wifi, Bluetooth and GPS weren't working properly
我的修理方法
After changing this part, everything works perfectly.
我的建议
It's easy when you follow ifixit instruction.
用户头像
我的问题
The phone is 3+ years old and the battery would die in 3 hours of continuous usage. It also wouldn't charge unless you bend the lightning cable into the dock connector at an angle and keep it that way which is (holy ####) extremely frustrating and damages the appliance.
我的修理方法
The repair itself went with a . . .
用户头像
我的问题
... is the Multi Tool Roll does not come in fashion colors. I would reorder as soon as I knew I could get a green one
我的修理方法
我的建议
... is the Multi Tool Roll does not come in fashion colors. I w . . .
用户头像
我的问题
no charge
我的修理方法
fantastic
我的建议
non ascoltare solo apple
用户头像
我的问题
Broken hard disk cable
我的修理方法
It took only 5 minutes. Easy, fast, secure and now it's working! Don't be shy to repair something by yourself. And I've saved money!
我的建议
First of all, practice, get familiar with your mac. Watch tutorials.
用户头像
我的问题
Power button was not working, and the battery was failing.
我的修理方法
It was ok. The battery was rather hard to peel out, but after that, the power button procedure was ok.
我的建议
The guide says to un-hinge the power button before the cable is detached from the back case. I found that I had to take the volume buttons . . .
用户头像
我的问题
My aunt forgot the take out of the pocket her iPhone 5S before putting the jeans in the washer machine.
我的修理方法
There was no sign of sulfate or sparks on the logic board pins. We need to change the Dock port and probably the Battery but I am waiting on her desicion to spend $80 and it may be work or not.
我的建议
Yo m . . .
用户头像
我的问题
The 1TB hard drive in my 2011 iMac started failing. Luckily I had everything backed up on externals. I was super excited to see that iFixit had a dual hard drive kit, so I ordered that plus a 500GB SSD for my boot drive and a 3TB HDD for bulk storage.
我的修理方法
The repair went amazingly well. A co-worker helpe . . .
用户头像
我的问题
Upon visiting the Apple store to complain about the useless power button that mysteriously stopped working on my iPhone, I was told that my only option was to purchase an expensive "out of warranty" replacement. Fortunately, after researching the problem, I chose to buy a repair kit from iFixit ins . . .
用户头像
我的问题
cant afford a new replacement phone
我的修理方法
repair went fine
我的建议
dont need to remove the battery
显示更多
