Essential Electronics Toolkit
  • 关闭360°
  • 360°
360
Limit 5 per customer.
$19.99
$19.99
当产品有货时,我们将给你发送消息。
换块电池,让 iPhone「满血复活」
维修工具包价格在 $16.99
产品详细说明
功能
功能
Our most economical do-everything toolkit. The Essential Electronics Toolkit is what you need for the most essential electronics repairs—like screen and battery swaps—and everything you need for most household DIY fixes.
Get started in electronics repair with all the bits and precision tools to handle your most urgent screen breaks and battery swaps. Or simply upgrade your home DIY toolkit with what you need to service door knobs, home appliances, eyeglasses, and more.
Kit Includes
维修的故事
用户头像
Sean Lichtenstein's Story Photo #1330869
我的问题
Cracked/Smashed IPhone 6S screen
我的修理方法
It went well! A little more difficult than I expeted but the guides were a fundamental help with this repair- I would not have been able to complete it without them!
It was a bit tricky getting the Home button in place as well as the earpiece speaker and camera- but . . .
用户头像
Andrew Kubicka's Story Photo #1183403
我的问题
I was completely unable to use any of the functions of Wifi, bluetooth or location servies. I would not pick up any wifi networks, any bluetooth connections would connect and disconnect a few times before never connecting again, and location services could barely pick up my location (on occation up . . .
用户头像
我的问题
It had the 3 beep of death. I purchased 2, 8s of ram for a total of 16, however. It would not allow this. So ended up with 10gb. Initially I thought I had a bad top ram slot. But the 2gb took. But had to put them in one at a time to test them. I truly would not wanted to replace the logic board. S . . .
用户头像
我的问题
I replaced the battery, fan, and right speaker/subwoofer
我的修理方法
Took my time and reviewed videos over and over. Everything went smoothly.
我的建议
for images, I would show the before and after shot of how to remove certain connections. I didn't know how to remove a certain piece from your website, but found out fro . . .
用户头像
我的问题
My MacBook Pro Early Rubber Feet has left and I was replace it with MBP Rubber Feet that i was buy on iFixit Store. I buy Essential Electronics Toolkits to do this.
我的修理方法
First, i replace botoom case my MacBook Pro and then replace 4 rubber feet.
Just do it.
我的建议
You don't need adhesive 'cause iFixit MBP Rubber . . .
用户头像
我的问题
Still using the original battery in 2018 so decided it was time.
我的修理方法
Replacement went smoothly -- except for the enclosed tools. I recommend purchasing the toolkit to avoid stripping the screws.
我的建议
The four screwdrivers are really just toys; please either spring for a better set of just do away with them.
用户头像
我的问题
Hard drive died. My first delve into computer guts. Drive seemed fine, head not stuck, but made clicking noise. Decided I wouldn't be able to recover. Maybe circuit board... Bought Evo 256Gig SSD and while looking around the delightful ifixit site, discovered the discussions about upgrading the . . .
用户头像
我的问题
Problems: 1) GPS was not identifying my location very well. gave a rather large cone of uncertainty and turn-by-turn directions was not usable. 2) wifi connectivity was suspect. my device had to be very close to a router to connect. 3) bluetooth connectivity was also bad. my device had to be very cl . . .
用户头像
我的问题
Regardless of charger or cable, charge rate was only 300 mA. New battery did not help.
我的修理方法
Even with the iFixit tools (very nice), the case got a little dinged. The glue holding the board was more tenacious than expected.
我的建议
Take your time. Use little force. Don't bend boards or cables more than necessary. B . . .
用户头像
我的问题
I've previously had Apple repair the cable while it was under warranty and that cable subsequently went out about a year after that. I was able to scavenge a HD cable from another MacBook Pro (mid 2011) and while not ideal, it worked well enough. Now I had the money and time to double down on the ca . . .
显示更多
