Anti-Static Wrist Strap
  • Anti-Static Wrist Strap
US$7.99
US$7.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Prevent electrostatic damage.
  • Helps protect your electronics from accidental electrostatic discharge (ESD) damage during repairs.
  • Ground yourself while working on sensitive electronics to prevent static charge build-up.
  • Custom manufactured by iFixit for "American" sized wrists. Most anti-static wrist straps are made for use in manufacturing throughout Asia, and do not pass our ergonomics test, if they fit at all!
"Rapid static dissipation by a wrist strap ground is required to prevent voltage spikes. Simple movements such as lifting one foot off the floor or raising one arm from a conductive table mat may change body capacitance by as much as 10% to 30%. Uncontrolled, the capacitively created voltage may reach several hundred volts or more."
-3M Technical Brief
Specifications:
  • Band Size: .75" x 8" unstretched
  • Band Type: Elastic with adjustable buckle
  • Band Material: Polyester/stainless steel weave
  • Cord Length: Coiled, 6 Feet / 2 Meters
  • Cord Resistance: 1 M(Ohm)
维修的故事
Jamie FC's Story Photo #927036
Jamie FC's Story Photo #927037
Jamie FC's Story Photo #927039
我的问题
My beloved phone — I've had it for years and I couldn't bear to chuck 'er in once the charger started to go. I decided to stretch myself, put my money where my mouth was, and crack open my own baby.
我的修理方法
This was by far the most comprehensive repair I've done. After almost 80 screen repairs on various d . . .
MissHeather's Story Photo #593000
我的问题
The computer was overheating pretty bad and it was hard to watch video or even play a simple game without the computer shutting off.
我的修理方法
It went really well. The tools made the whole process go really smoothly.
我的建议
I recommend taking your time, research the job before you start doing it, lay out all your tool . . .
我的问题
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
我的修理方法
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
我的问题
Mac would not boot. Initialized the hard drive, installed a new OS and replaced the battery. I did it all with the 54 bit driver set.
我的修理方法
The Mac is up and working again. Quick and responsive.
我的建议
Apple wouldn't sell me a replacement battery but IFIXIT did. Thanks for the guides, parts and tools.
我的问题
MacBook not charging
我的修理方法
The repair went pretty smoothly. The trickiest part was removing the keyboard ribbon cable. The instructions were not clear to show the actual location of the section that you have to flip up. With patience it wasn't too difficult to figure out. The project tray came in very . . .
我的问题
My computer was so slow I couldn't get anything done. I was running on 2GB ram.
我的修理方法
Ordered a 4GB RAM chip and installed it in one of the slots, leaving the 1GB chip in the other. The installation was pretty easy. Had to do it twice because the first time it seems the computer didn't recognize it. 2nd ti . . .
我的问题
Recently, I augmented the RAM and put a new SSD hard drive into my old late 2006 core 2 duo white mac book.
I heard a guy at a computer store say that the best thing you could do was to clean out your computer, but I didn't believe him. Anyhow, I realised my computer was definitely overheating when . . .
我的问题
I am the office administrator for a small 5 staff non-profit. My boss' 2011 MBP had a bad RAM stick and an old HDD. I recommended to max out the RAM, put in a new SSD, and install Yosemite.
我的修理方法
Very very very easy. I kinda wish it took longer with more steps, I was enjoying the process so much. Having th . . .
我的问题
My iPhone 4s battery was basically good for 3/4 of a day as just a phone, and about 3 hours of 4G connectivity. I could literally watch the battery tick down 1% every couple minutes. I had previously taken apart the laptop I'm typing on, cleaned it and reassembled it, so I felt fairly confident abou . . .
我的问题
thought i had a bad power supply because iMac had a problem turning on
我的修理方法
the repair went well 1 hour start to finish. wish i would have read a few more forums turned out it is the button after all according to apple my entire housing needs to be replaced in order to fix this. but i read a forum an . . .
显示更多
