1.5" Thin Putty Knife
  • 1.5" Thin Putty Knife
US$6.99
US$6.99
当产品有货时,我们将给你发送消息。
产品详细说明
描述
描述
Sneak into tough devices.
  • Use to separate upper and lower cases in tightly attached devices.
  • Perfect for opening the Mac mini or iPod Classic.
  • Fine-tune your knife throwing abilities with this 1.5" putty knife.
  • Does not come with ninja certification.
维修的故事
David Williams's Story Photo #997081
我的问题
When we ordered our Mac Mini years ago, we maxed out the RAM at 4 GB. Still runs but the new iOS and apps bogged it down constantly. Found out that the iOS upgrades allowed us to expand the RAM to 8 GB. So ordered the RAM and a few tools from iFixit to upgrade it.
我的修理方法
Repair instructions were very eas . . .
Philip Kapp's Story Photo #906083
我的问题
I needed a new battery.
我的修理方法
Very well! It worked perfectly!
我的建议
To remove the glued batteries I used an iFixit putty knife and heated it with a miniature blowtorch. Then I placed the heated iFixit putty knife underneath the batteries which melted the glue and enabled me to lift the batteries out. The battery . . .
我的问题
I broke my power port when plugging it in to my comp
我的修理方法
It was quite the process... The blue ifixit opening tools were pretty much worthless as they aren't sharp enough to get in the crevices. I think I might have damaged the plug-in part for the battery as I tried plugging it back in but the power isn' . . .
我的问题
The headphone jack was defective on ipod classic.
我的修理方法
Hard to get back off, this a question of the correct selection of tools, the blue plastic leavers are a bit crap! Good to have a few 1-2" putty knifes & a few levers to insert into gaps once you have started to create a gap.
Ipod work as it should a . . .
我的问题
My water bottle leaked in my pack and got my i-Pod thoroughly soaked. I tried the sack-of-rice drying method to no avail and decided to open the case or throw it away.
我的修理方法
Until you see how the "clips" work, it is difficult to imagine how they work. I checked several websites and You-Tube videos, but sti . . .
我的问题
My iPod Classic 160gb stopped working. I've had it for many years and use it almost every day so, I thought maybe it just needed a new battery.
我的修理方法
I have no real experience at repairing things but, my husband can repair almost anything and I have worked with him on many projects. Soooooo. . .when my . . .
我的问题
The Mac Mini I had was extremely slow and thankfully had the ability to repair the processor, I did so.
我的修理方法
It went well, the tools I purchased did the job masterfully.
我的建议
Be patient, be kind, and use cable ties.
我的问题
I had a problem with the battery. It would no longer hold a charge. While I was at it I decided to put in a new screen and hard drive. (Just to see if I could)
我的修理方法
Could have been better. The videos I watched didn't quite explain how hard the back case was to take off. Other then that it was very simple. . . .
我的问题
Battery dead after 7 years
我的修理方法
Relatively easy, I did not damage the rear case. However something is strange after the change: the battery is charging when linked to my iMac or an external battery but not with the apple charger plugged to the wall power outlet.
我的建议
Must be done with patience, Not need to rush
我的问题
The battery stopped holding a charge. Could only use it when plugged into the wall.
我的修理方法
Smoother than i expected. Some minor cosmetic damage (bending of sides) but i mean this iPod is coming up on 8 years old and i've dropped it a few times. No shortage of nicks and dings on it already. To have it fixed . . .
显示更多
