修复你的物品
维修的权力
配件 & 工具
iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
  • iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
US$139.99
US$139.99
当产品有货时,我们将给你发送消息。
Manta 螺丝刀工具包
112 bits for every fix.
Upgrade Your Toolbox
Manta 螺丝刀工具包
产品详细说明
描述
描述
Bring your iMac back to life!
兼容性
兼容性
  • 2.4 (EMC No. 2210) and 2.66 (EMC No. 2210) GHz 20" Intel iMacs
产品规格
产品规格
Part #:
661-4670 , 614-0438
安装视频
兼容性
iMac Intel 20" EMC 2133 and 2210
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
维修的故事
用户头像
Chee Yong Koo's Story Photo #364177
我的问题
Power supply went unserviceable after 5 years of usage.
我的修理方法
it definitely took an hour or so but the repair was slow, steady but smooth.
我的建议
Current guide was good enough however major improvements could have been made in the video where certain parts of "disconnecting cables /parts " of hardware made cleared . . .
用户头像
我的问题
I woke up one morning to find a dead iMac (2008 20" 2.66 ghz), and then noticed the house power had gone out during the night. I like the iMac, and it synchs with my iPhone, so I decided to repair it. Also, it had 13,000 family photos going back to 2003.
我的修理方法
The repair went smoothly, even with help from . . .
用户头像
我的问题
My wife has a 20" Intel iMac (EMC No. 2210) which had slowed to a crawl and eventually failed to boot. I have always had PC's and wasn't shy about swapping out hard drives and performing basic hardware repairs or upgrades. I wasn't eager to go out and spend a couple grand on another Apple computer . . .
用户头像
我的问题
the iphone had a broken glass display was working.The imac mod a1224 emc nr 2210 stopped working for a friend in the music aranger and musican.powersuply was the problem i found out with help fom your informative site and videos.worked with electroniks for 30 years.
我的修理方法
The iphone 5s i have bougth a disp . . .
用户头像
我的问题
Power supply burned out during electrical storm. Insurance declined to fix or replace as machine no longer supported by Apple. Insurance company paid me $250 which more than covered the cost of a replacement power supply from iFixit.
我的修理方法
No problems, easy-peasy, with instructions from iFixit lady on yout . . .
用户头像
我的问题
20" iMac EMC 2210: Overheating power supply caused a slight discoloration of the LCD screen on the corner in front of the power supply. It was also causing intermittent short term cut off of power which caused problems with the Hard Drive, That was the reason it was brought in for service.
我的修理方法
Used the . . .
用户头像
我的问题
We had a brownout and the iMac shut itself off. It wouldn't turn back on. I unplugged it from the wall for thirty seconds and it turned on and shut itself off again. It would not run longer than 5 minutes. So I ordered the power supply.
我的修理方法
The repair went smoothly. The only trouble I had with the disass . . .
用户头像
我的问题
My 20" iMac simply stopped working one evening recently while I was streaming music to my Apple TV. I did a little research and found there were diagnostic lights on the bottom. I saw light #1 (which indicates if the unit is getting power) was blinking and "guessed" the power supply had gone bad. . . .
用户头像
我的问题
My desktop iMac suddenly does not turn on any more - I tried everything I can check from internet sources, from checking power cables to reseting power management, all unsuccessful. Thanks to an iFixit guide and comments, I checked the power supply unit inside iMac and appeared to be the problem, z . . .
用户头像
我的问题
My iMac started acting funky. At first it just did not want to start up after a power failure. Sometimes it would just sit there and a few hours later power on. Strange very strange. Finally, it simply refused to power up. No chimes, no fan noise, no nothing. Just a door stop. What could it b . . .
显示更多
