MacBook Upper Case Cable
  • MacBook Upper Case Cable / Silver
US$24.99
US$24.99
产品详细说明
描述
描述
Replace the cable that transmits the data from the power button, keyboards, and trackpad to your MacBook's logic board.
兼容性
兼容性
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
产品规格
产品规格
Part #:
922-7991
兼容性
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
维修的故事
用户头像
我的问题
bad, bad, bad cable
我的修理方法
The repair went awesome. Thanks iFixit!!!
我的建议
Do what iFixit says.....
用户头像
我的问题
Trackpad and keyboard continuously seen as being disconnected and reconnected by USB daemon. Internet was unanimous that issue was USB upper case cable.
我的修理方法
Replaced the part (and replaced a few stripped screws too)... but issue persists. The problem : faulty upper ase cover.
我的建议
When your mac starts going ha . . .
用户头像
我的问题
For some time I had problems with the computer recognizing my keyboard and touchpad and one day it just stopped turning on, so i opened the computer and i saw that the MacBook upper case cable was broken in one place probably because of many times of opening and closing the computer, 7 years old com . . .
用户头像
我的问题
Failed Logic Board. But in the process of removing the upper case to get to the logic board, the upper case cable connector fell to bits, but ifixit had one in stock.
我的修理方法
The repair went easy peasy with ifixit's guide, seriously. Not a screw left over.
我的建议
Having the right tools makes all the difference.
用户头像
我的问题
I had opened up my MacBook to replace my optical drive with a SATA cable so that I could connect my external SATA drive internally and get the speeds that I need. After opening the case so many times, I guess the cable just broke. This being the case, my trackpad and internal keyboard no longer func . . .
用户头像
我的问题
I was upgrading a computer for a kid down the street. The original plan was to upgrade his hard drive and RAM. Once we accomplished that we decided to upgrade his OS as well. That's where the "scope creep" began. His DVD player was kapoot and we couldn't get the Snow Leopard DVD out of his machi . . .
用户头像
我的问题
I started out having to replace the Dvd drive as it was not working. I was putting everything back when I broke the keyboard ribbon cable.
我的修理方法
I used the ifixit repair guides and it went smoothly. They are fantastic! My MacBook is working fine with a brand new dvd superdrive. The keyboard and the b . . .
用户头像
我的问题
I couldn't start the laptop, so I had to fix it.
我的修理方法
It went perfectly, I've received the parts in just five days, by regular mail. Considering that I live in Spain. That was very fast.
我的建议
Just be very careful with the Mackbook Upper case and it should go fine, and that in the other end of the cable(the on . . .
用户头像
paulxpac's Story Photo #230145
我的问题
My MacBook (Model 1181) is in pristine condition, so getting a new one seemed wasteful. After doing an internet search on possible causes of intermittent track pad and keyboard failure, I found it to be a consistent problem with these models. I ran thru the prescribe checks and decided to change out . . .
用户头像
lxtc's Story Photo #225913
我的问题
My upper case cable didn't like disassemblies much so I had to get a more cooperative one. / Excédé par des démontages intempestifs mon câble de clavier a décidé de cesser toute collaboration avec moi, d'où remplacement par un collègue au caractère plus docile.
我的修理方法
Thanks to the guide, all went . . .
显示更多
