修复你的物品
维修的权力
商店
MacBook Unibody (A1342) Trackpad
  • MacBook Unibody (A1342) Trackpad
  • 360°
360
US$74.99
US$74.99
产品详细说明
描述
描述
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Unibody (Model A1342) laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
兼容性
兼容性
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
产品规格
产品规格
Part #:
922-9551, 922-9175, 661-9551
兼容性
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
维修的故事
用户头像
我的问题
The track pad went from not clicking to moving around sporadically while you tried to click on anything.
我的修理方法
It was very simple when following the directions.
我的建议
After installing the track pad dont screw on the bottom immediately. Turn on the computer and check the 'clickage'. You might have to tighten or lo . . .
用户头像
我的问题
I helped my niece purchase her first used computer. When it arrived the trackpad wouldn't click. Instead of sending it back for a refund and realizing we would lose the shipping to and from and then not have a computer, I decided to go ahead and replace it myself.
我的修理方法
Part was delivered in a timely manne . . .
用户头像
我的问题
Using ifixit repair guide I bought and installed a new trackpad.
我的修理方法
Following the guide It was easy and problem solver in 15 minutes.
我的建议
Ifixit, The right guide at The right place with the right parts!
用户头像
我的问题
Old and dead trackpad.
我的修理方法
Only took ten minutes!
我的建议
Works like new! Took me ten minutes to replace the trackpad.
Will order again from iFixit as they use quality parts.
用户头像
我的问题
My white unibody macbook was having problems with the trackpad. After days of searching the internet, trying software fixes, cleaning, checking battery, etc, nothing worked. I finally decided to go for it and buy a new replacement Trackpad with screws, the #00 Phillips Screwdriver, and the Y1 Tri- . . .
用户头像
我的问题
Trackpad clicker didn't work
我的修理方法
The instructions were very clear and replacement went easy.
我的建议
After installing the new trackpad the clicker still didn't work. I took it apart and noticed an adjustment screw that actuates the detent. I increased it and then it worked great. I didn't bother to try the old tr . . .
用户头像
我的问题
The battery swelled in the middle so much that it pushed the track pad up our of the computer.
我的修理方法
Trackpad replacement seemed at first not to work, new pad was also out of alignment, but shifting the strips that hold it in slightly solved the problem and the track pad aligned. Worked perfectly. Putting . . .
用户头像
我的问题
My trackpad lost it's clicking ability
我的修理方法
Replace with a brand new trackpad bought from www.ifixit.com
我的建议
Please don't rush with any of your repairs. That's what I got from my past and present experiences.
用户头像
我的问题
My son dropped his phone onto his trackpad and chipped the corner of it.
我的修理方法
We received the part and tool within a couple of days. I reviewed the online repair process and ten minutes later we were up and running again.
我的建议
I would definitely use Ifixit again and recommend the online tutorials. They are ea . . .
用户头像
我的问题
My MacBook track pad was acting up. Unable to click, not very responsive to touch.
我的修理方法
The repair process went smooth thanks for the useful detailed guide and all the tools and accessories provided by iFixit.com.
我的建议
If the track pad just not clickable (or having trouble clicking), just need to readjust the . . .
显示更多
