修复你的物品
维修的权力
配件 & 工具
MacBook Unibody (A1342) Lower Case
  • MacBook Unibody (A1342) Lower Case
US$149.99
US$149.99
当产品有货时,我们将给你发送消息。
Manta 螺丝刀工具包
112 bits for every fix.
Upgrade Your Toolbox
Manta 螺丝刀工具包
产品详细说明
描述
描述
Replace a dented or scratched lower case compatible with a Model A1342 MacBook Unibody laptop.
兼容性
兼容性
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
产品规格
产品规格
Part #:
922-9183, 661-5974
Model #:
A1342
兼容性
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
维修的故事
用户头像
gveldman's Story Photo #462277
我的问题
A few weeks ago the rubber coating released it self, caused by the heat, from the lowercase of our Macbook, end 2009 version. Because the Apple replacement program was not applied on this Macbook, I decided to repair it my self. The Macbook is in perfect state, including 4GB memory and running Yosem . . .
用户头像
我的问题
Rubberized on original back was coming off. Rubber stretched and buckled over time
我的修理方法
Easy, eight screws and done. Finding the correct back from other vendors was the greatest headache
我的建议
call Fixit first.
用户头像
我的问题
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
用户头像
我的问题
Bottom was missing screws, and rubber was coming off the metal. Was not affecting operation of the laptop. More cosmetic than anything.
我的修理方法
Got the new bottom and screws in the mail a few days after I ordered them, removed the old bottom, and installed the new bottom within minutes. Very easy to do.
我的建议
N . . .
用户头像
我的问题
Heavy-duty processing warms up the underside of my MacBook, and eventually the rubber layer on the base-plate released itself from the metal where the heat is most intense and created a large bubble. The computer couldn't sit flat on a tabletop anymore, so a replacement base-plate was required.
我的修理方法
The n . . .
用户头像
我的问题
My wife's Macbook stopped charging. After a short troubleshooting I figured out that the Magsafe connector was at fault. Also, as the laptop was mostly used on soft covered surfaces, cooling was poor, causing some overheating of the lower case, hence causing bubbling of the non slippery rubberized s . . .
用户头像
我的问题
Because it was broken.
我的修理方法
10 min. Done.
我的建议
It's great. Never grab your chick and through it to the bed when the laptop is sitting there. The display screen may suffer.
用户头像
我的问题
The old case was coming apart and needed to be replaced.
我的修理方法
Very easy, just remove old case and replace with the new one.
我的建议
Having the right screwdriver made the job easier. Would recommend that first.
显示更多
